Cisco 4900 High CPU-OBFL INTR slot-1 process
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
318   468462204    17412256      26904 86.61% 23.31% 14.51%   0 OBFL INTR slot-1
Ok. Lets try to fix errors on Te1/3 and see this issue solves with that.
These errors are mostly due to physical layer issue. Please arrange to have a check/replace cables SFP etc on both ends of this connection first.
Madhu
9 Replies 9
Mark Malone
Can you post further info that does not look high its only 14.51% over 5 mins , the 86.61% is for the 5sec output this can be caused by anything even someone taking a show tech
If you think you have high cpu can you post show proc cpu sorted and show proc cpu history
Hello Tigma,
OBFL is logs onboard failures. Can you please let us know how frequent this is happening.
Please have a check for interface errors and see if any port is taking a lot of errors. Sometimes that can cause it.
show interfaces counters errors
Also please share the below
sh process cpu sorted | ex 0.00%
sh ver
Madhu
show process cpu history in attach file
sho int cou err
Port            CrcAlign-Err Dropped-Bad-Pkts Collisions   Symbol-Err
Te1/3                1525111                0          0    554695871
Te1/8                      0                0          0          148
Port               Undersize  Oversize  Fragments      Jabbers
Te1/3                      0         0       7272            0
Port            Deferred-Col False-Car  Carri-Sen Sequence-Err
Te1/3                      0         0          0       710174
You really needs to keep an eye on Te1/3 to see these counters are incrementing or not.
If they are investigate physical layer to see if there is a problem (SFP, cable, patch panel etc).
This could potentially add to CPU due to OBFL.
Also please attach
sh loggin onboard
Madhu.
****Please rate all useful posts***
sho proc cpu sor | ex 0.00%
I will provide to you again when it high cpu.
sho ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M), Version 15.1(2)SG1, RELEASE SOFTWARE (fc3)
Thank you very much.
sho int cou err
Te1/3                1525230                0          0    554734565
Te1/8                      0                0          0          148
Te1/3                      0         0       7275            0
Te1/3                      0         0          0       710236
sho log onboard
PID: WS-C4900M         , VID: 2  , SN: JAE16520xxx
UPTIME SUMMARY INFORMATION
First customer power on : 03/11/2011 23:47:20
Total uptime            :   1 years  18 weeks   2 days  20 hours   0 minutes
Total downtime          :   2 years  44 weeks   5 days   5 hours  18 minutes
Number of resets        : 32
Number of slot changes  : 1
Current reset reason    : 0x0
Current reset timestamp : 01/22/2014 05:05:50
Current slot            : 1
Current subslot         : 0
Current uptime          :   1 years  17 weeks   5 days  20 hours   0 minutes
Reset  |        |
Reason | Count  |
No historical data to display
ENVIRONMENT SUMMARY INFORMATION
MM/DD/YYYY HH:MM:SS   Ins count    Rem count
                    VID PID                  TAN          Serial No
No environment summary data to display
TEMPERATURE SUMMARY INFORMATION
Number of sensors          : 2
Sampling frequency         : 1 minutes
Maximum time of storage    : 10 minutes
Sensor                            |   ID  | Maximum Temperature 0C
air outlet                          0     45
air inlet                           1     32
Temp                         Sensor ID
0C     1    2
INTERRUPT SUMMARY INFORMATION
Name                                              |  ID | Offset | Bit |  Count
ipp high                                             10   0x9003     0     9400
ipp low                                              11   0x8000     0     9399
ERROR MESSAGE SUMMARY INFORMATION
Facility-Sev-Name      | Count | Persistence Flag
MM/DD/YYYY HH:MM:SS
Madhu
I changed another X2 to the Te1/4 instead, I haven’t seen the issue anymore.
Hi ,
Thanks for updating. Please mark it as answered if this post has helped you.
Madhu
