CISCO 4908G-L3 Trunk To CISCO 3560 PoE Switch
joe.cordova20131
Beginner
Beginner
I am needing a little help configuring a CISCO 3560 PoE Switch to our network. We have 4 vlans configured on the CISCO 4908G-L3  and CISCO 3500xl using EtherChannel, Bridging and Routing and ISL Trunks Between Switches. We recently have purchased a CISCO 3560 PoE switch for our Wireless Access Points. How would I configure the new 3560 Switch to communicate to the rest of the network. I notice when I tried to add the gig0/3 on the 3560 to port group 8 it does not recogize the command? Any help would be greatly appreciated thanks...
Network Diagram:
Catalyst 4908G-L3 Config: 10.10.1.1
ipx routing 0030.78fe.a0000
bridge irb
interface Port-channel1
no ip address
no ip directed-broadcast
hold-queue 300 in
interface Port-channel1.1
encapsulation isl 1
 no ip redirects
bridge-group 1
interface Port-channel1.10
encapsulation isl 10
 no ip redirects
bridge-group 10
interface Port-channel1.20
encapsulation isl 20
no ip redirects
bridge-group 20
interface Port-channel1.30
encapsulation isl 30
no ip redirects
bridge-group 30
interface Port-channel1.40
encapsulation isl 40
no ip redirects
bridge-group 40
interface Port-channel2
encapsulation isl 1
 no ip redirects
bridge-group 1
no ip redirects
bridge-group 10
no ip redirects
bridge-group 20
no ip redirects
bridge-group 30
interface Port-channel2.40
no ip redirects
bridge-group 40
interface GigabitEthernet1
no ip address
channel-group 1
interface GigabitEthernet2
no ip address
channel-group 1
interface GigabitEthernet3
no ip address
channel-group 2
interface GigabitEthernet5
no ip address
interface GigabitEthernet5.1
encapsulation isl 1
no ip address
bridge-group 1
interface GigabitEthernet5.10
no ip address
bridge-group 10
interface GigabitEthernet5.20
no ip address
bridge-group 20
interface GigabitEthernet5.30
no ip address
bridge-group 30
interface GigabitEthernet5.40
no ip address
bridge-group 40
interface GigabitEthernet6
no ip address
shutdown
interface GigabitEthernet7
no ip address
shutdown
interface GigabitEthernet8
no ip address
shutdown
interface BVI1
ip address 10.10.1.1 255.255.255.0
no ip route-cache cef
interface BVI10
ip address 10.10.10.1 255.255.255.0
ipx network 1000
interface BVI20
ip address 10.10.20.1 255.255.255.0
ipx network 2000
interface BVI30
ip address 10.10.30.1 255.255.255.0
ipx network 3000
interface BVI40
ip address 10.10.40.1 255.255.255.0
ipx network 4000
bridge 1 protocol ieee
bridge 1 route ip
bridge 10 protocol ieee
bridge 10 route ip
bridge 10 route ipx
bridge 20 protocol ieee
bridge 20 route ip
bridge 20 route ipx
bridge 30 protocol ieee
bridge 30 route ip
bridge 30 route ipx
bridge 40 protocol ieee
bridge 40 route ip
bridge 40 route ipx
Configuration Catalyst 3512XL - 10.10.1.10 - To Admin IDF
interface GigabitEthernet0/1
switchport mode trunk
port group 1
interface GigabitEthernet0/2
port group1
Configuration Catalyst 3512XL - 10.10.1.20
port group 1
port group1
Configuration Catalyst 3512XL - 10.10.1.20 - To Main Building IDF
port group 1
port group1
port group 1
port group1
Configuration Catalyst 3560PoE - 10.10.1.30 - To NEW SWITCH IDF
interface GigabitEthernet0/3
Reza Sharifi
Hall of Fame Expert Hall of Fame Expert
Hall of Fame Expert
The 3650 series switches do not support ISL trunking. You need to use dot1.q trunk, which is default on the switch.
interface gi0/3
 switchport trunk allowed vlan xx, xx, xx
Recognize Your Peers
