Can I just load this new IOS on this switch, or do I need to do an upgrade to another IOS before placing this image on?
You can go directly from your current IOS to the new version
Do I need any additional licences to upgrade to this IOS?
Yes, your current license level is IP Base and the new image is Enterprise. So you need a new license. Talk to your sales rep.
Is there anything else that I should consider before the upgrade?
Yes, make sure your flash has enough space for both images.
