Cisco 6506-E Replacement and support for replacement
otislee
Hi Community,
Somewhat new to networking but I was recently tasked with finding a replacement for a Cisco 6506-e and also getting support to help move the config from the 6506-e to the new appliance. Any help with this or point me in the right direction would be much appreciated.
marce1000
 - The thread below gives some hints :
                      https://community.cisco.com/t5/switching/what-switch-to-replace-6509/td-p/3695353
  Also have a look at :
                https://www.cisco.com/c/en/us/products/switches/switch-selector.html
 M.
Joseph W. Doherty
The most "like" replacement would be the 9407 (which is sort of the newer version of the 4507).
Scott Hodgdon
otislee,
Is this being used for user access (PoE, 10/100/1000, etc) or Dist / Core (10G agg, no PoE, etc) ? Can you provide a full "show module" output ? That may help to determine which replacement is most appropriate.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking Group
Leo Laohoo
What port density are you "chasing" for? 1-, 10-, 40- or 100 Gbps?
