Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco 6509 Catalys - VSS
opnineopnine
With a 6509 catalyst configured with vss can I configure  port-channel?
Thanks.
Yes. That should not be an issue
From my lab where we have port chnanel configured.It includes the VSL links as well.
S720_VSS#sh etherc sum <snip>
Group  Port-channel  Protocol    Ports
10     Po10(RU)         -        Te1/5/4(P)     Te1/5/5(P)     Te1/6/4(P)
                                 Te1/6/5(P)
20     Po20(RU)         -        Te2/5/4(P)     Te2/5/5(P)     Te2/6/4(P)
                                 Te2/6/5(P)
30     Po30(SD)         -
31     Po31(SD)         -
64     Po64(SU)        LACP      Gi1/5/3(P)     Gi1/6/3(P)     Gi2/5/3(P)
                                 Gi2/6/3(P)
-Raj
Rajeshkumar Gatti
The VSS just aggregates 2 switches into one logical entity with a single control plane.
Port channel configuration is exactly the same as what you could do on a standalone 6500.
-Raj
Hello Rajeshkumar,
thanks for you update, so I can create a port-channl on any catalyst and IOS device with VSS configured?
thanks.!
                                 Te1/6/5(P)
                                 Te2/6/5(P)
30     Po30(SD)         -
31     Po31(SD)         -
                                 Gi2/6/3(P)
-Raj
