Cisco-6509, High Cpu utilization.
sumitsept3
We are experiencing very high cpu utilization on our 6509 switch, is there any possibility we can fix the issue ?
sh proc cpu
CPU utilization for five seconds: 77%; one minute: 75%; five minutes: 60%
PID 5Sec 1Min 5Min Process
1 0.4% 4.4% 4.3% kernel
3 0.0% 0.0% 0.0% qdelogger
4 0.0% 0.0% 0.0% devc-pty
5 0.0% 0.0% 0.0% devc-mistral.proc
6 0.0% 0.0% 0.0% pipe
7 0.0% 0.0% 0.0% dumper.proc
4104 0.0% 0.0% 0.0% pcmcia_driver.proc
4105 0.0% 0.0% 0.0% bflash_driver.proc
12298 0.0% 0.0% 0.0% mqueue
12299 0.0% 0.0% 0.0% flashfs_hes.proc
12300 0.0% 0.0% 0.0% dfs_bootdisk.proc
12301 0.0% 0.0% 0.0% ldcache.proc
12302 0.0% 0.0% 0.0% watchdog.proc
12303 0.0% 0.0% 0.0% syslogd.proc
12304 0.0% 0.0% 0.0% name_svr.proc
12305 0.0% 0.0% 0.0% wdsysmon.proc
12306 0.0% 0.0% 0.0% sysmgr.proc
16386 0.0% 0.0% 0.0% chkptd.proc
16403 0.0% 0.0% 0.0% sysmgr.proc
16404 0.0% 0.0% 0.0% syslog_dev.proc
16405 0.0% 0.0% 0.0% itrace_exec.proc
16406 0.0% 0.0% 0.0% packet.proc
16407 0.0% 0.0% 0.0% installer.proc
16408 45.0% 42.0% 33.8% ios-base
16409 0.0% 0.0% 0.0% fh_fd_oir.proc
16410 0.0% 0.0% 0.0% fh_metric_dir.proc
16411 0.0% 0.0% 0.0% fh_fd_snmp.proc
16412 0.0% 0.0% 0.0% fh_fd_none.proc
16413 0.0% 0.0% 0.0% fh_fd_intf.proc
16414 0.0% 0.0% 0.0% fh_fd_gold.proc
16415 0.0% 0.0% 0.0% fh_fd_timer.proc
16416 0.0% 0.0% 0.0% fh_fd_ioswd.proc
16417 0.0% 0.0% 0.0% fh_fd_counter.proc
16418 0.0% 0.0% 0.0% fh_fd_rf.proc
16419 0.0% 0.0% 0.0% fh_fd_cli.proc
16420 0.0% 0.0% 0.0% fh_server.proc
16421 0.0% 0.0% 0.0% fh_policy_dir.proc
16422 27.1% 25.2% 18.9% tcp.proc
16423 0.0% 0.0% 0.0% ipfs_daemon.proc
16424 0.4% 0.4% 0.4% raw_ip.proc
16425 0.0% 0.0% 0.0% inetd.proc
16426 2.2% 1.9% 1.4% udp.proc
16427 0.2% 0.4% 0.4% iprouting.iosproc
16428 0.4% 0.2% 0.2% cdp2.iosproc
765997 0.0% 0.0% 0.0% tftp_fs.proc
6 Replies 6
Giuseppe Larosa
Hello Sumit,
may you post as an attachment file the following?
sh proc cpu sorted 1min
that allows to see the processes that use most resources
sh proc cpu history that provides whole cpu usage over time as histograms
and also allows to understand if there are recurring peaks in usage or it is steady high
Hope to help
Giuseppe
sh proc cpu
CPU utilization for five seconds: 86%; one minute: 88%; five minutes: 90%
1 0.0% 2.7% 3.8% kernel
16408 48.1% 50.4% 51.8% ios-base
16422 33.0% 31.0% 29.6% tcp.proc
16424 0.2% 0.6% 0.5% raw_ip.proc
16426 2.5% 2.4% 2.5% udp.proc
16427 1.5% 0.5% 0.5% iprouting.iosproc
16428 0.4% 0.3% 0.2% cdp2.iosproc
show proc cpu his
8889899999998888899999988888888889889898889998888898888899
8891800102009859901110099998998885783709980008899919989800
100 *
90 **********************************************************
80 **********************************************************
70 **********************************************************
60 **********************************************************
50 **********************************************************
40 **********************************************************
30 **********************************************************
20 **********************************************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
Hello Sumit,
two processes are causing the high cpu usage:
please provide IOS image name and type of cpu you may be hitting a bug or the device is under some form of attack with malformed TCP packets or it may be some misconfiguration.
Have you added / changed the configuration recently ?
There is a companion device colocated, if yes how does it behave ?
if you have a registered account with enough privileges you can try to use
https://www.cisco.com/pcgi-bin/Support/OutputInterpreter/home.pl
it will ask you to post
sh ver
sh proc cpu
This is the output interpreter feedback:
SHOW PROCESS CPU NOTIFICATIONS (if any)
INFO: Total CPU Utilization is comprised of process and interrupt percentages.
Total CPU Utilization: 86%
Process Utilization: %
Interrupt Utilization: %
These values are found on the first line of the output:
CPU utilization for five seconds: x%/y%; one minute: a%; five minutes: b%
Total CPU Utilization: x%
Process Utilization: (x - y)%
Interrupt Utilization: y%
Process Utilization is the difference between the Total and Interrupt (x and y).
The one and five minute utilizations are exponentially decayed averages (rather
than an arithmetic average), therefore recent values have more influence on the
calculated average.
ERROR: Total CPU Utilization is at 90% for the past 5 minutes, which is very high
(>90%).
NOTE: This is an exponentially decayed average rather than an arithmetic average,
therefore recent events have a greater effect than past events.
This can cause the following symptoms:
- Input queue drops
- Slow performance
- Slow response in Telnet or unable to Telnet to the router
- Slow response on the console
- Slow or no response to ping
- Router doesn't send routing updates
The following processes are causing excessive CPU usage:
PID CPU Time Process
16408 50.4% ios-base
16422 31.0% tcp.proc
TRY THIS: If there is no indication of any problem in logged messages, then the
problem could possibly be caused by a bug in the IOS. Using the Bug ToolKit, run
a search for the specified process to see if any bugs have been reported. If this
is not caused by a bug, this device may be overloaded. Investigate upgrading this
device or moving some CPU intensive tasks to a second device.
INFO: If you need help from a Customer Support Engineer in the Cisco TAC, capture
the 'show tech-support' command output (from enable mode) before contacting Cisco
TAC. Also, if the high CPU utilization is caused by a process, please capture the
'show stacks {pid}' command output (where pid is the process ID of the process
causing the high CPU utilization). If the problem is caused by a bug in IOS, please
relay the bug ID to the Cisco Customer Support Engineer handling the case.
NOTE:
- Make sure all debugging commands in your router are turned off by issuing the
undebug all or no debug all command.
Hope to help
Giuseppe
Hello Sumit,
I made a search for release 12.2(18)SXF16 with search key high cpu on bug toolkit
CSCek78237
High CPU on ATM PA Helper process on PA-A3-T3
Info Information on this bug
Fixed 2
CSCdz83100
Multicast pkts should not be policy routed in CEF
Fixed 2
CSCsa51770
Configuration of RSPAN on 12.2(18)SXD3 causes high CPU.
Fixed 3
CSCsv40527
High CPU in IP RIB when LI enabled
Fixed 3
Hope to help
Giuseppe
Thanks for all your support , i am still trying to fix it at the earliest.
We are using
s72033-advipservicesk9_wan-vz.122-18.SXF6.bin
Hello Sumit,
all the bugs I've listed could apply to yours image.
if you like you can send a filtered version of your configuration.
Be aware that some problems come out from having two devices competing for something like to be HSRP active for the same group.
So if you have a pair of C6509 look at what happens at the other device.
I would suggest you to open a TAC service request if you hadn't made any configuration change on the device or in some neighboring device yesterday or the day before yesterday.
Hope to help
Giuseppe
