04-02-2013 07:24 PM - edited 03-07-2019 12:35 PM
Hi Guys,
Can someone please tell me if my Cisco 6509 with supervisor engine WS-SUP720-BASE will support a 16-Port 10GbE Copper Module.
I'm not sure if I'll need to upgrade my supervisor engine in order to get a 10 Gb module to work.
Here's the show module from the swich:
Mod Ports Card Type Model Serial No.
1 8 8 port 1000mb GBIC Enhanced QoS WS-X6408A-GBIC SAL06240ZNC
2 16 SFM-capable 16 port 1000mb GBIC WS-X6516A-GBIC SAL0805TR3N
3 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1328TT1C
4 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1118MZJW
5 2 Supervisor Engine 720 (Active) WS-SUP720-BASE SAD081005AU
6 2 Supervisor Engine 720 (Hot) WS-SUP720-BASE SAD082008VB
7 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1407BJ30
8 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAD0816060G
9 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAD07470450
Mod MAC addresses Hw Fw Sw Status
1 0009.11bf.8980 to 0009.11bf.8987 2.1 5.4(2) 8.3(0.156)RO Ok
2 0008.7dca.87fc to 0008.7dca.880b 3.0 7.2(1) 8.3(0.156)RO Ok
3 0026.0b7e.25a0 to 0026.0b7e.25cf 11.3 7.2(1) 8.3(0.156)RO Ok
4 001b.54e7.ef60 to 001b.54e7.ef8f 11.1 7.2(1) 8.3(0.156)RO Ok
5 000d.2910.2eec to 000d.2910.2eef 3.1 7.7(1) 12.2(18)SXD Ok
6 000d.bda4.0180 to 000d.bda4.0183 3.1 7.7(1) 12.2(18)SXD Ok
7 68ef.bd5e.89a0 to 68ef.bd5e.89cf 11.3 7.2(1) 8.3(0.156)RO Ok
8 000f.f74b.9fda to 000f.f74b.a009 10.0 7.2(1) 8.3(0.156)RO Ok
9 000d.ed72.c2a0 to 000d.ed72.c2cf 6.0 7.2(1) 8.3(0.156)RO Ok
Mod Sub-Module Model Serial Hw Status
5 Policy Feature Card 3 WS-F6K-PFC3A SAD081005T1 2.2 Ok
5 MSFC3 Daughterboard WS-SUP720 SAD081007T2 2.2 Ok
6 Policy Feature Card 3 WS-F6K-PFC3A SAD081909J9 2.3 Ok
6 MSFC3 Daughterboard WS-SUP720 SAD082009YZ 2.2 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
6 Pass
7 Pass
8 Pass
9 Pass
Ross.
Solved! Go to Solution.
04-02-2013 07:48 PM
Also, here is the data sheet for compression:
04-02-2013 07:30 PM
Here are all the Sup modules that support the 16 port 10Gig copper:
The 16-port 10 Gigabit Ethernet copper module is interoperable with all models of the Cisco Catalyst 6500 Series Virtual Switching Supervisor Engine 720 with 10 Gigabit Ethernet uplinks or Cisco Catalyst 6500 Series Supervisor Engine 720, including VS-S720-10G-3C, VS-S720-10G-3CXL, WS¬-Sup720, WS-Sup720-3B, and WS-Sup720-3BXL. Note that when DFCs are mixed in the same chassis, the chassis will operate in the lowest common mode.
More info:
04-02-2013 07:34 PM
Ok, I see you just posted sh module
You need to upgrade your Sup.
04-02-2013 07:38 PM
Ok thanks. Can you recommend a supervisor engine that will support this 10gb module. We only need the supervisor enigne to have GB uplinks.
04-02-2013 07:46 PM
All the Sup I listed above have 10 and 1Gig interfaces If you know, you never need VSS, you can use 720-3BXL.
If you have the budget you can use VS-S720-10G-3CXL. This also support VSS in case you need it in the future.
You probably can get the VS sup for the same price as 3B, since Cisco is pushing 2T these days.
04-02-2013 07:48 PM
