787
Highlighted
Beginner
Cisco 6509E power Supply problem!!!PLs help
Hi all,
My 6509E Chasis cannot detect the all the line card except the ws-x6k-sup2-2ge. It is running hybrid which Cat0S on layer 2 and IOS at Layer 3.The more detail log is in the attachment.
is it this problem is because the CATOS version cannot support ?My CatOS version is cat6000-sup2k8.8-4-5.bin.
thks
-Gilbert
10 REPLIES 10
Highlighted
Participant
Re: Cisco 6509E power Supply problem!!!PLs help
the error log certainly looks like the power supply is not supported.
What power supply have you used?
Highlighted
Beginner
I'm using WS-CAC-3000W,but previously it is working fine for me.last 2 day i just tftp to do something on it and the all line card i can detect.
thks
Highlighted
Beginner
Hi Gilbert,
Just went through Cisco Document and it says the following,
"%SYS-1-SYS_OVERPWRRTNG:System drawing more power than the power supply rating"
The switch generates periodic %SYS-1-SYS_OVERPWRRTNG syslog messages.
This message indicates that the system draws more power than the power supply rating. The power management LED is lit red. This condition occurs only when the system is fully configured and the Supervisor Engines draw unequal power.
The workaround is to reseat the power supplies and then upgrade the Supervisor Engine software to a version that supports the hardware. Refer to the Supported Hardware section of the "Cisco Catalyst 6500 Series Switches Release Notes" for the relevant release.
try and let us know.
ThiyaguVG.
Highlighted
Beginner
i already reseat the power supply and may i know what Supervisor engine version which can support ?
thks
-gilbert
Highlighted
Beginner
What are the linecards installed in the switch?
Highlighted
Beginner
hi,
WS-X6348.
thks
Highlighted
Beginner
Unless I get worong, I think that the suggest replacement product part number is WS-SUP720-3B
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_end-of-life_notice0900aecd80423d31.html
Highlighted
Beginner
hi,
my sup is WS-X6K-Sup2-2GE, Is it may i know Power Supply hardware problem or CatOS problem.
Thks
-Gilbert
Highlighted
Beginner
Any 1 can help pls!!!!
-gilbert
Highlighted
Beginner
How many WS-X6348 do you have installed?
Which is the exact model? RJ45-V, RJ21-V or RJ-45?
Did you try to toggle the confiugration from power redundancy-mode redundant to power redundancy-mode combined?
Did you try to use only one PS?
Content for Community-Ad
