cisco 6513 switch module "minor error"
Hi Team,
I have Cisco 6513 switch in production and module 1 shows,Mod  Online Diag Status "Minor Error"
#sh module 1
Mod Ports Card Type                              Model              Serial No.
  1   48  48-port 10/100 RJ45 Ethernet Module    WS-X6148A-45AF     SAL1127TGVW
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  001c.585f.9220 to 001c.585f.924f   4.3   8.4(1)       8.5(0.46)RFW Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  IEEE Voice Daughter Card    WS-F6K-GE48-AF     SAL11413EPD  1.4    Ok
  1  Minor Error
5 Replies 5
Reza Sharifi
You may have a bad module.  Try reseating the module physically.
Module Status is Minor Error
After vyou insert a module into a slot, the module shows a status of Minor Error from the show module command output. This is probably due to a bad module, a bad slot, or a badly seated module.
Link:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/97065-oir-mod-catsw.html
Thank you
yeah,we are trying to get new module,but let me confirm on reseat the module
Check
sh diag result modul 1 detail
to see if any test is failing.  Also check logs and sh env .
Most of the time a reseat fixes , else replace it.
Madhu
InayathUlla Sharieff
Try to reseat the module(remove the module and insert it back). That should resolve the issue.
Thank you,
i think we already tried for it..let me check....
