09-01-2015 09:26 AM - edited 03-08-2019 01:36 AM
i'm connecting two Cisco 6800 in VSS and the ports that i connecto from 6800 supervisor 10G isn´t working.
When i connect the two ports with X210GLR slots it doesn't come up, i've tested the patches with a loop in one supervisor and thast ok, all the X2 interfaces i've tested ein same way, and seems ok too.
The supervisor is a VS-SUP2T-10G
The X2 interfaces is X2-10G-LR
Both 6800 have the 15.1(2)SY5 ewith advanced ip services.
Someone have a clue, about what is going worng here?
09-01-2015 09:40 AM
Based on the Sup2T datasheet I can see that the x2 interfaces are supported:-
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/catalyst-6500-series-supervisor-engine-2t/data_sheet_c78-648214.html
Second did you do the loop testing back to back on the ports first ?
09-01-2015 10:00 AM
Yes i made the loop, and the ports came up.
09-01-2015 10:06 AM
Which means ports are up.
Can you try connecting the ports directly between the devices?
