Cisco 7206VXR unexpected Booting with:Last reset from watchdog reset
risky widjakso
We have issue booting cisco 7206VXR with NPE-G2 on IOS c7200p-advsecurityk9-mz.124-4.XD11.bin. On show version can see that the Router reset (
Last reset from watchdog reset).Below the capture :
Cisco IOS Software, 7200 Software (C7200P-ADVSECURITYK9-M), Version 12.4(4)XD11, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 03-Oct-08 15:52 by ccai
ROM: System Bootstrap, Version 12.4(4r)XD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD2, RELEASE SOFTWARE (fc2)
JKTPZBIIT1-6-WAN02-7206 uptime is 59 minutes
System returned to ROM by error - a Software forced crash, PC 0x1193CEC at 11:06:00 IND Thu Mar 17 2011
System restarted at 14:24:33 IND Fri Jan 24 2014
System image file is "disk2:/c7200p-advsecurityk9-mz.124-4.XD11.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 35461839
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.1
6 slot VXR midplane, Version 2.11
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 400 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
C7200 PA Jacket Card present in I/O slot (VAM2+ Encryption/Compression engine,)
3 FastEthernet interfaces
3 Gigabit Ethernet interfaces
16 Serial interfaces
1 Virtual Private Network (VPN) Module
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
We search on bugtoolkit with ID CSCed93913, CSCea05927. Many issue like this on cisco 7200 but with NPE-G1, are this issue the same like happen for NPE-G2 we have?
And from caveat bug CSCed93913, CSCea05927 doesn't have the solusion yet this time. Have anyone have solution about this issue?
0 Replies 0
