Cisco 800 template with BGP
iano8888888
Has anyone got a template to use for a Cisco 800 router that will be configured with BGP on the WAN side and 192.168.10.0/30 on the LAN side.
LAN just needs to get out to the BGP network via NAT.
Anything appreciated.
Francesco Molino
It's quite difficult to give a template without knowing all details of what you're trying to achieve.
To do a simple BGP peering, the config will looks like:
router bgp xxxx --> your AS number (private AS any number between 64512 and 65534)
  bgp router-id x.x.x.x --> Usually it's a loopback address used as router-id
  neighbor x.x.x.x remote-as xxx --> Info given by your WAN provider (IP of the WAN router and their AS)
After that, lots more option but with this config you'll be able to build up a BGP peering and learn routes from your WAN provider.
If you're using VRFs, you have to configure the right address-family.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
