Cisco 831 RIP Issues
danielcummins
I am trying to create a small network to test the functionality of my Cisco 831 routers.  I've designed the following infrastructure:
HostA (192.168.2.2/24)
Connected to:
e0 (192.168.2.1/24) Router1 (172.16.1.2/24) e1
Connected to:
Switch
Connected to:
e1 (172.16.1.1/24) Router2 (192.168.1.1/24) e0
Connected to:
HostB (192.168.1.2/24)
For some reason, the HostB network is not being detected by Router1 and HostA is not being detected by Router2.  It seems that RIP might be the problem.
Here are the sh run outputs for both routers:
Router1
version 12.3
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip ips po max-events 100
no ftp-server write-enable
interface Ethernet0
ip address 192.168.2.1 255.255.255.0
interface Ethernet1
ip address 172.16.1.2 255.255.0.0
duplex auto
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
router rip
version 2
network 172.16.0.0
network 192.168.0.0
no auto-summary
no ip classless
ip http server
no ip http secure-server
ip nat inside source list 101 interface Ethernet1 overload
access-list 100 permit ip any any
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
no crypto isakmp enable
interface Ethernet0
interface Ethernet1
ip address 172.16.1.1 255.255.0.0
duplex auto
interface Ethernet2
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
router rip
version 2
network 172.16.0.0
network 192.168.0.0
no auto-summary
no ip classless
ip http server
access-list 101 permit ip any any
control-plane
line con 0
no modem enable
transport output all
line aux 0
line vty 0 4
login
end
version 12.3
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
interface Ethernet0
interface Ethernet1
duplex auto
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
router rip
version 2
network 172.16.0.0
network 192.168.0.0
no auto-summary
no ip classless
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Router2
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
interface Ethernet0
interface Ethernet1
duplex auto
interface Ethernet2
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
duplex auto
speed auto
router rip
version 2
network 172.16.0.0
network 192.168.0.0
no auto-summary
no ip classless
ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
John Blakley
The first thing that I notice is that your network statements don't seem to be correct.
Router1:
router rip
version 2
network 172.16.0.0
network 192.168.0.0   <<<----- Should be 192.168.2.0
no auto-summary
Router2:
router rip
version 2
network 172.16.0.0
network 192.168.0.0
no auto-summary
router rip
version 2
network 172.16.0.0
network 192.168.0.0  <<<----- Should be 192.168.1.0
no auto-summary
Your switch should be set with:
router rip
version 2
network 172.16.0.0
network 192.168.0.0 <<< ---- Should be 192.168.2.0
no auto-summary
HTH,
John
*** Please rate helpful posts ****
HTH, John *** Please rate all useful posts ***
John Blakley
Router1:
router rip
version 2
network 172.16.0.0
no auto-summary
Router2:
router rip
version 2
network 172.16.0.0
network 192.168.0.0
no auto-summary
router rip
version 2
network 172.16.0.0
no auto-summary
router rip
version 2
network 172.16.0.0
no auto-summary
HTH,
John
Thanks!  That fixed it.
Glad I could help
