Join Customer Connection to register!
1043
Alex Fray
Beginner
Cisco 877w - ADSL packet loss
Hi, i'm having some issues with a Cisco 877W router connected to an ADSL line (UK). I have layer 3 connectivity to/from the router to our data centers across the private broadband cloud but i'm getting alot (approx 10%) packet loss which is causing the user issues working in our citrix environment.
There are no errors on the vlan, atm or dialer interface and from the sh dsl interface command below, the attentuation is low and the only errors i can see to possibly explain this are the CRC, ES and header errors (shown below). The ISP have said the line is fine so are reluctant to try anything, could this be that the download/upload speed is to high and needs to be lowered for a more stable connection? is there anything configurable on the router i can try to get rid of this packet loss?
cisco877w#sh dsl int
ATM0
Alcatel 20190 chipset information
ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT) Annex A
ITU STD NUM:    0x03                            0x1
Vendor ID:      'STMI'                          'ALCB'
Vendor Specific: 0x0000                          0x0000
Vendor Country:  0x0F                            0x0F
Chip ID:        C196P (1) DFE BOM:        DFE3.0 Annex A (1)
Capacity Used:  95%                            48%
Noise Margin:    7.0 dB                        23.0 dB
Output Power:    10.0 dBm                        12.0 dBm
Attenuation:      8.0 dB                          4.0 dB
FEC ES Errors:    0                              0
ES Errors:      1195                            78
SES Errors:      0                              0
LOSES Errors:    0                              0
UES Errors:      0                              0
Defect Status:  None                            None
Last Fail Code:  None
Watchdog Counter: 0x25
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:    0x00
Interrupts:      8384 (0 spurious)
PHY Access Err:  0
Activations:    22
LED Status:      ON
LED On Time:    100
LED Off Time:    100
Init FW:        init_AMR-3.0.014_no_bist.bin
Operation FW:    AMR-3.0.014.bin
FW Source:      embedded FW Version:      3.0.14
Interleave            Fast    Interleave              Fast
Speed (kbps):          7616                0          448                0
Cells:                30491                0      1731096                0
Reed-Solomon EC:      31894                0            1                1
CRC Errors:            124                0            7                1
Header Errors:          114                0            0                1
Total BER:                65535E-255            0E-0
Leakage Average BER:      65535E-255            0E-0
Bitswap:              enabled            enabled
Bitswap success:          0                  0
Bitswap failure:          0                  0
1 REPLY 1
paolo bevilacqua
Hall of Fame Master
Attentuation is low but so is noise margin unfortunately.
To be on the safe side, you should update IOS and ADSL firmware.
