Join Customer Connection to register!
1160
Alex Fray
Beginner
Cisco 877W Router - DSL connectivity issue
I'm using a Cisco 877W router which connects to a private broadband network using PPPoA. I have installed many other 800 series routers on broadband lines successfully so am familiar with DSL but cannot resolve this issue.
When i connect my router to the line i get a solid Carrier detect light and when doing a debug atm events i get "showtime" so all good. However when i debug ppp negotiation i am not able to authenticate. It is not that my CHAP/PAP username and password is wrong its that i don't even get to that point.
The router continually does a confreq over 30 times which times out which would indicate no response from the ISP:
000040: *May  4 11:54:51.157 BST: Vi2 LCP: O CONFREQ [REQsent] id 44 len 10
000041: *May  4 11:54:51.157 BST: Vi2 LCP:    MagicNumber 0x75D5C4D8 (0x050675D5C4D8)
000042: *May  4 11:54:53.173 BST: Vi2 LCP: Timeout: State REQsent
However after 30+ time i eventually get a response (4 minutes later):
000179: *May  4 11:58:11.864 BST: Vi2 LCP: O CONFREQ [ACKsent] id 84 len 10
000180: *May  4 11:58:11.864 BST: Vi2 LCP:    MagicNumber 0x75D8D4DD (0x050675D8D4DD)
000181: *May  4 11:58:11.896 BST: Vi2 LCP: I CONFACK [ACKsent] id 84 len 10
000182: *May  4 11:58:11.896 BST: Vi2 LCP:    MagicNumber 0x75D8D4DD (0x050675D8D4DD)
000183: *May  4 11:58:11.896 BST: Vi2 LCP: State is Open
000184: *May  4 11:58:11.896 BST: Vi2 PPP: Phase is AUTHENTICATING, by the peer
000185: *May  4 11:58:11.896 BST: Vi2 CHAP: I CHALLENGE id 57 len 38 from "ERX15.Birmingham3"
000186: *May  4 11:58:15.960 BST: Vi2 CHAP: I CHALLENGE id 58 len 38 from "ERX15.Birmingham3"
000187: *May  4 11:58:20.061 BST: Vi2 CHAP: I CHALLENGE id 59 len 38 from "ERX15.Birmingham3"
000188: *May  4 11:58:21.913 BST: Vi2 AUTH: Timeout 1
000189: *May  4 11:58:24.161 BST: Vi2 CHAP: I CHALLENGE id 60 len 38 from "ERX15.Birmingham3"
000190: *May  4 11:58:28.262 BST: Vi2 CHAP: I CHALLENGE id 61 len 38 from "ERX15.Birmingham3"
000191: *May  4 11:58:31.926 BST: Vi2 AUTH: Timeout 2
000192: *May  4 11:58:32.358 BST: Vi2 CHAP: I CHALLENGE id 62 len 38 from "ERX15.Birmingham3"
000193: *May  4 11:58:36.459 BST: Vi2 CHAP: I CHALLENGE id 63 len 38 from "ERX15.Birmingham3"
000194: *May  4 11:58:40.559 BST: Vi2 CHAP: I CHALLENGE id 64 len 38 from "ERX15.Birmingham3"
000195: *May  4 11:58:41.944 BST: Vi2 AUTH: Timeout 3
000196: *May  4 11:58:44.660 BST: Vi2 CHAP: I CHALLENGE id 65 len 38 from "ERX15.Birmingham3"
000197: *May  4 11:58:48.773 BST: Vi2 CHAP: I CHALLENGE id 66 len 38 from "ERX15.Birmingham3"
000198: *May  4 11:58:51.961 BST: Vi2 AUTH: Timeout 4
000199: *May  4 11:58:52.869 BST: Vi2 CHAP: I CHALLENGE id 67 len 38 from "ERX15.Birmingham3"
000200: *May  4 11:58:56.966 BST: Vi2 LCP: I TERMREQ [Open] id 120 len 4
000201: *May  4 11:58:56.966 BST: Vi2 LCP: O TERMACK [Open] id 120 len 4
000202: *May  4 11:58:56.966 BST: Vi2 PPP: Sending Acct Event[Down] id[4]
000203: *May  4 11:58:56.970 BST: Vi2 PPP: Phase is TERMINATING
000204: *May  4 11:58:58.970 BST: Vi2 LCP: Timeout: State TERMsent
000205: *May  4 11:58:58.970 BST: Vi2 LCP: State is Closed
000206: *May  4 11:58:58.970 BST: Vi2 PPP: Phase is DOWN
Now to me this indicates an inbound packet from the ISP but now my router doesn't respond.
Is this a configuration issue with my router or an ISP problem. I have read the Cisco DSL Troubleshooting for PPPoA document but it doesn't cover this. my configuration is below:
interface ATM0
no ip address
no ip mroute-cache
no shut
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer1
ip address 10.x.x.1 255.255.255.254
ip inspect myfw out
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxx
ppp chap password yyyy
ppp pap sent-username xxxx password yyyy
ppp ipcp dns request
ppp ipcp wins request
hold-queue 224 in
thanks Alex
5 REPLIES 5
paolo bevilacqua
Hall of Fame Master
Which IOS are you using ?
Can you send "show dsl itnterface", "show int atm0". To rule out layer 1 issues.
I had the PSTN provider come out to check the line and they confirmed it was ok. The fact i get a carrier detect should mean the line is ok. I'm just a bit confused that i do occassionally see some traffic from the ISP but don't complete the PPP negotiation.
IOS - c870-advsecurityk9-mz.124-24.T4.bin
sh int atm0 -
ATM0 is up, line protocol is up
Hardware is MPC ATMSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 448 Kbit/sec, DLY 820 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5  AAL2, PVC mode
10 maximum active VCs, 64 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:02:58
Queueing strategy: Per VC Queueing
15 packets input, 485 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
33 packets output, 525 bytes, 0 underruns
0 unknown protocol drops
sh dsl interface -
ATM0
Alcatel 20190 chipset information
ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT) Annex A
ITU STD NUM:    0x03                            0x1
Vendor ID:      'STMI'                          'ALCB'
Vendor Specific: 0x0000                          0x0000
Vendor Country:  0x0F                            0x0F
Chip ID:        C196P (1) DFE BOM:        DFE3.0 Annex A (1)
Capacity Used:  100%                            59%
Noise Margin:    8.0 dB                        18.0 dB
Output Power:    15.5 dBm                        12.0
dBm Attenuation:    52.0 dB                        31.5 dB
FEC ES Errors:    0                              0
ES Errors:      23                              1
SES Errors:      0                              0
LOSES Errors:    0                              0
UES Errors:      0                              0
Defect Status:  None                            None Last Fail Code:  None Watchdog Counter: 0xAB Watchdog Resets: 0 Selftest Result: 0x00 Subfunction:    0x00
Interrupts:      8252 (0 spurious)
PHY Access Err:  0
Activations:    1
LED Status:      ON
LED On Time:    100
LED Off Time:    100
Init FW:        init_AMR-3.0.014_no_bist.bin
Operation FW:    AMR-3.0.014.bin
FW Source:      embedded
FW Version:      3.0.14                 Interleave            Fast    Interleave              Fast
Speed (kbps):          1888                0          448                0
Cells:                13620                0    337927022                0
Reed-Solomon EC:      35751                0            0                0
CRC Errors:              25                0            6                0
Header Errors:          17                0            0                0
Total BER:                7419E-12              0E-0
Leakage Average BER:      9931E-12              0E-0
Bitswap:              enabled            enabled
Bitswap success:          0                  0
Bitswap failure:          0                  0
LOM Monitoring : Disabled
DMT Bits Per Bin 000: output omitted by alex fray
Training log buffer capability is not enabled
The circuit has very high attenuation and quite a few errors.
I think there is layer 1 problem here.
However the router also responds strangely to PPP, can you try a different IOS ?
What is a good db range for attenuation?
i upgraded the IOS from T4 to T5 (c870-advsecurityk9-mz.124-24.T5.bin ) but still no joy, same result.
One random link, you can find more by searching.
http://www.naschenweng.info/2008/10/16/adsl-significance-of-snr-and-attenuation
Please remember to rate useful posts clicking on the stars below.
