Cisco 877W Wireless Connection Dropping Off
ciscoxchen
I do need again your help. Sorry. I got issue with my 877w wireless connection.
Wireless connection is OK when 887w rebooted, and speed is good.
ping 10.10.10.1 get 10ms response.
Just after 1-3 minutes since rebooted, the wireless connection become terrible, either >1000ms response or just dropped off and hard to connect back, until I reboot the 887w again.
The wireless light and wireless data light seem to be just normal, one solid, one flashing.
The wired connections are all very good all the time.
below is a piece of config code:
dot11 syslog
dot11 ssid double5
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 104A060C071B175E59
no ip source-route
interface Dot11Radio0
no ip address
ip nat inside
ip virtual-reassembly
encryption vlan 1 mode ciphers tkip
ssid double5
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
ip nat inside
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
no ip address
ip nat inside
ip tcp adjust-mss 1452
bridge-group 1
Leo Laohoo
Is this an 877 or 887?
Why do you have "ip nat inside" in your Dot110 interface?
Is the antenna attached?
Have you tried scanning if your wireless is interferring with someone else's?
paolo bevilacqua
Try IOS update.
Alos, this should post in WAN or Wireless, not SBCS. Your product is not SB.
