cisco 887 ppp issue
alanc3141592654
Hey All,
I've just purchased a new cisco 887va - C887VA-W-A-K9  But I can't get it to receive a IP address from the provider.
All the interfaces are up and so is the controller.
But it does not receive a IP address from the provider
I'm pretty sure I have set the configuration correct, does anything look obviously wrong? the provider is TPG in Australia.
HOSTNAME#show run
Building configuration...
Current configuration : 4750 bytes
! Last configuration change at 05:03:46 UTC Thu Oct 11 2012 by alan
! NVRAM config last updated at 04:06:59 UTC Thu Oct 11 2012 by alan
version 15.1
hostname HOSTNAME
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 qo6mUF6LT0pj9qmbwnmCUEV9XzDVEU6ZEHTW7bCwsgU
no aaa new-model
ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.10.1 10.10.10.2
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
login on-failure log
no ipv6 cef
license udi pid C887VA-W-A-K9 sn FTX163681J
username XXXX privilege 15 secret 4 qo6mUF6LT0pj9qmbwnmCUEV9XzDVEU6ZEHTW7bCwsgU
controller VDSL 0
operating mode adsl2+
interface ATM0
no ip address
ip directed-broadcast
no ip proxy-arp
no ip route-cache
atm ilmi-keepalive
interface ATM0.1 point-to-point
description TPG
ip mask-reply
no ip route-cache
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
description ###Inside Network###
ip address 10.10.10.1 255.255.255.0
ip tcp adjust-mss 1452
interface Vlan10
ip address 10.100.10.1 255.255.255.0
interface Dialer0
description ###ADSL - Outside###
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname XXXX
ppp chap password 0 XXXX
ppp pap sent-username XXXX password 0 XXXX
ppp ipcp dns accept
ppp ipcp route default
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list NAT_ACL_ALLOWED interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list standard NAT_ACL_ALLOWED
permit 10.10.10.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
dialer-list 1 protocol ip permit
no cdp run
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
cadet alain
is your atm interface up/up ?
if so can you do: debug ppp negotiation and debug ppp authentication  and shut it/no shut it
Post the output of the debug log.
Regards.
Alain
the ATM interface is up.
I did notice "virtual-access 2 is up down"
here is the output of the debugs and show commands for trouble shooting.. Sorry there is so much of it
HOSTNAME#
HOSTNAME#start here
% Chat scripts can not be run on the Console or Virtual lines
HOSTNAME#
HOSTNAME#
HOSTNAME#
HOSTNAME#
HOSTNAME#show run int dialer0
Current configuration : 442 bytes
interface Dialer0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname xxxx
ppp chap password 0 xxxx
ppp pap sent-username xxxx password 0 xxxx
ppp ipcp dns accept
no cdp enable
end
HOSTNAME#show run int atm0
Current configuration : 116 bytes
interface ATM0
no ip address
no ip proxy-arp
no ip route-cache
atm ilmi-keepalive
end
HOSTNAME#show run int atm0.1
Current configuration : 185 bytes
description TPG
ip mask-reply
no ip route-cache
pvc 8/35
end
HOSTNAME#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES NVRAM  up                    up
ATM0.1                     unassigned      YES unset  up                    up
Dialer0                    unassigned      YES NVRAM  up                    up
Ethernet0                  unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  up                    down
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
NVI0                       unassigned      NO  unset  up                    up
Virtual-Access1            unassigned      YES unset  up                    up
Virtual-Access2            unassigned      YES unset  up                    down
Vlan1                      10.10.10.1      YES NVRAM  up                    up
Vlan10                     10.100.10.1     YES NVRAM  up                    down
Wlan-GigabitEthernet0      unassigned      YES unset  up                    up
wlan-ap0                   10.10.10.1      YES TFTP   up                    up
HOSTNAME#show control
HOSTNAME#show controllers v
HOSTNAME#show controllers vDSL 0
Controller VDSL 0 is UP
Daemon Status:           Up
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IFTN'
Chip Vendor Specific:   0x0000                   0x71B9
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:                C887VA-W 15.1(4)M
Serial Number Far:
Modem Version Near:    15.1(4)M
Modem Version Far:     0x71b9
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         ADSL2+
Trained Mode:            G.992.5 (ADSL2+) Annex A
TC Mode:                 ATM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Trellis:                 ON                       ON
Line Attenuation:        18.5 dB                  8.4 dB
Signal Attenuation:      18.5 dB                  8.9 dB
Noise Margin:            12.1 dB                 13.2 dB
Attainable Rate:        12880 kbits/s            1020 kbits/s
Actual Power:             0.0 dBm                12.1 dBm
Total FECS:             27506                    0
Total ES:               4                        0
Total SES:              1                        0
Total LOSS:             0                        0
Total UAS:              0                        0
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
Bit swap:               191                      0
Full inits:             4
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name (version)
VDSL            embedded        VDSL_LINUX_DEV_01212008 (1)
Modem FW  Version:      110506_1916-4.02L.03.A2pv6C032b.d23i
Modem PHY Version:      A2pv6C032b.d23i
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0            10442             0              1020
Previous Speed:           0            10438             0              1020
Total Cells:              0         16912815             0           1637715
User Cells:               0               99             0               588
Reed-Solomon EC:          0            27506             0                 0
CRC Errors:               0               45             0                 0
Header Errors:            0              112             0                 0
Interleave (ms):       0.00            11.21          0.00              1.13
Actual INP:            0.00             2.12          0.00              0.00
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
HOSTNAME#
HOSTNAME#
HOSTNAME#config t
Enter configuration commands, one per line.  End with CNTL/Z.
HOSTNAME(config)#int atm0
HOSTNAME(config-if)#do debug ppp negotiation
PPP protocol negotiation debugging is on
Oct 11 10:01:54.713: Vi2 LCP: O CONFREQ [REQsent] id 2 len 10
Oct 11 10:01:54.713: Vi2 LCP:    MagicNumber 0x74B0D396 (0x050674B0D396)
Oct 11 10:01:54.713: Vi2 LCP: Event[Timeout+] State[REQsent to REQ
% Ambiguous command:  "do debug ppp ne"
Oct 11 10:01:56.729: Vi2 LCP: O CONFREQ [REQsent] id 3 len 10
Oct 11 10:01:56.729: Vi2 LCP:    MagicNumber 0x74B0D396 (0x050674B0D396)
Oct 11 10:01:56.729: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:01:58.745: Vi2 LCP: O CONFREQ [REQsent] id 4 len 10
Oct 11 10:01:58.745: Vi2 LCP:    MagicNumber 0x74B0D396 (0x050674B0D396)
Oct 11 10:01:58.745: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:02:00.769: Vi2 LCP: O CONFREQ [REQsent] id 5 len 10
Oct 11 10:02:00.769: Vi2 LCP:    MagicNumber 0x74B0D396 (0x050674B0D396)
Oct 11 10:02:00.769: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
% Ambiguous command:  "do debug ppp "
Oct 11 10:02:02.777: Vi2 LCP: O CONFREQ [REQsent] id 6 len 10
Oct 11 10:02:02.777: Vi2 LCP:    MagicNumber 0x74B0D396 (0x050674B0D396)
Oct 11 10:02:02.777: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]authen
Oct 11 10:02:04.793: Vi2 LCP: O CONFREQ [REQsent] id 7 len 10
Oct 11 10:02:04.793: Vi2 LCP:    MagicNumber 0x74B0D396 (0x050674B0D396)
Oct 11 10:02:04.793: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]tication
PPP authentication debugging is on
Oct 11 10:02:06.809: Vi2 LCP: O CONFREQ [REQsent] id 8 len 10
Oct 11 10:02:06.809: Vi2 LCP:    MagicNumber 0x74B0D396 (0x050674B0D396)
Oct 11 10:02:06.809: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:02:08.824: Vi2 LCP: O CONFREQ [REQsent] id 9 len 10
Oct 11 10:02:08.824: Vi2 LCP:    MagicNumber 0x74B0D396 (0x050674B0D396)
Oct 11 10:02:08.824: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]shut
Oct 11 10:02:10.840: Vi2 LCP: O CONFREQ [REQsent] id 10 len 10
Oct 11 10:02:10.840: Vi2 LCP:    MagicNumber 0x74B0D396 (0x050674B0D396)
Oct 11 10:02:10.840: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:02:11.972: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to down
Oct 11 10:02:11.972: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di0
Oct 11 10:02:11.972: Vi2 PPP: Sending cstate DOWN notification
Oct 11 10:02:11.972: Vi2 PPP: Processing CstateDown message
Oct 11 10:02:11.972: Vi2 PPP DISC: Lower Layer disconnected
Oct 11 10:02:11.972: PPP: NET STOP send to AAA.
Oct 11 10:02:11.972: Vi2 LCP: O TERMREQ [REQsent] id 11 len 4
Oct 11 10:02:11.972: Vi2 LCP: Event[CLOSE] State[REQsent to Closing]
Oct 11 10:02:11.972: Vi2 PPP: Phase is TERMINATING
Oct 11 10:02:11.972: Vi2 LCP: Event[DOWN] State[Closing to Initial]
Oct 11 10:02:11.972: Vi2 PPP: Phase is DOWN
Oct 11 10:02:12.752: %LINK-5-CHANGED: Interface ATM0, changed state to administratively down
Oct 11 10:02:13.752: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to down
HOSTNAME(config-if)#do show ip int brief
ATM0                       unassigned      YES NVRAM  administratively down down
ATM0.1                     unassigned      YES unset  administratively down down
Virtual-Access2            unassigned      YES unset  down                  down
HOSTNAME(config-if)#no shut
Oct 11 10:02:47.888: %LINK-3-UPDOWN: Interface ATM0, changed state to down
Oct 11 10:02:55.132: %LINK-3-UPDOWN: Interface ATM0, changed state to up
Oct 11 10:02:56.132: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to up
Oct 11 10:02:57.796: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to up
Oct 11 10:02:57.796: %DIALER-6-BIND: Interface Vi2 bound to profile Di0
Oct 11 10:02:57.796: Vi2 PPP: Sending cstate UP notification
Oct 11 10:02:57.796: Vi2 PPP: Processing CstateUp message
Oct 11 10:02:57.796: PPP: Alloc Context [A9CC0EC]
Oct 11 10:02:57.796: ppp168 PPP: Phase is ESTABLISHING
Oct 11 10:02:57.796: Vi2 PPP: Using dialer call direction
Oct 11 10:02:57.796: Vi2 PPP: Treating connection as a callout
Oct 11 10:02:57.796: Vi2 PPP: Session handle[2F000028] Session id[168]
Oct 11 10:02:57.796: Vi2 LCP: Event[OPEN] State[Initial to Starting]
Oct 11 10:02:57.796: Vi2 PPP: No remote authentication for call-out
Oct 11 10:02:57.796: Vi2 LCP: O CONFREQ [Starting] id 1 len 10
Oct 11 10:02:57.796: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:02:57.796: Vi2 LCP: Event[UP] State[Starting to REQsent]
Oct 11 10:02:59.800: Vi2 LCP: O CONFREQ [REQsent] id 2 len 10
Oct 11 10:02:59.800: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:02:59.800: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:01.816: Vi2 LCP: O CONFREQ [REQsent] id 3 len 10
Oct 11 10:03:01.816: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:03:01.816: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:03.832: Vi2 LCP: O CONFREQ [REQsent] id 4 len 10
Oct 11 10:03:03.832: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:03:03.832: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:05.848: Vi2 LCP: O CONFREQ [REQsent] id 5 len 10
Oct 11 10:03:05.848: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:03:05.848: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:07.864: Vi2 LCP: O CONFREQ [REQsent] id 6 len 10
Oct 11 10:03:07.864: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:03:07.864: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:09.880: Vi2 LCP: O CONFREQ [REQsent] id 7 len 10
Oct 11 10:03:09.880: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:03:09.880: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:11.896: Vi2 LCP: O CONFREQ [REQsent] id 8 len 10
Oct 11 10:03:11.896: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:03:11.896: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:13.912: Vi2 LCP: O CONFREQ [REQsent] id 9 len 10
Oct 11 10:03:13.912: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:03:13.912: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:15.928: Vi2 LCP: O CONFREQ [REQsent] id 10 len 10
Oct 11 10:03:15.928: Vi2 LCP:    MagicNumber 0x74B1D204 (0x050674B1D204)
Oct 11 10:03:15.928: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:17.944: Vi2 PPP DISC: LCP failed to negotiate
Oct 11 10:03:17.944: PPP: NET STOP send to AAA.
Oct 11 10:03:17.944: Vi2 PPP: No remote authentication for call-out
Oct 11 10:03:17.944: Vi2 LCP: Event[Timeout-] State[REQsent to Stopped]
Oct 11 10:03:17.944: Vi2 LCP: Event[DOWN] State[Stopped to Starting]
Oct 11 10:03:17.944: Vi2 PPP: Phase is DOWN
Oct 11 10:03:18.944: PPP: Alloc Context [A9CC0EC]
Oct 11 10:03:18.944: ppp169 PPP: Phase is ESTABLISHING
Oct 11 10:03:18.944: Vi2 PPP: Using dialer call direction
Oct 11 10:03:18.944: Vi2 PPP: Treating connection as a callout
Oct 11 10:03:18.944: Vi2 PPP: Session handle[4C000029] Session id[169]
Oct 11 10:03:18.944: Vi2 LCP: Event[OPEN] State[Initial to Starting]
Oct 11 10:03:18.944: Vi2 PPP: No remote authentication for call-out
Oct 11 10:03:18.944: Vi2 LCP: O CONFREQ [Starting] id 1 len 10
Oct 11 10:03:18.944: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:18.944: Vi2 LCP: Event[UP] State[Starting to REQsent]
Oct 11 10:03:20.952: Vi2 LCP: O CONFREQ [REQsent] id 2 len 10
Oct 11 10:03:20.952: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:20.952: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:22.968: Vi2 LCP: O CONFREQ [REQsent] id 3 len 10
Oct 11 10:03:22.968: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:22.968: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:24.984: Vi2 LCP: O CONFREQ [REQsent] id 4 len 10
Oct 11 10:03:24.984: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:24.984: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:27.000: Vi2 LCP: O CONFREQ [REQsent] id 5 len 10
Oct 11 10:03:27.000: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:27.000: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:29.016: Vi2 LCP: O CONFREQ [REQsent] id 6 len 10
Oct 11 10:03:29.016: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:29.016: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:31.032: Vi2 LCP: O CONFREQ [REQsent] id 7 len 10
Oct 11 10:03:31.032: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:31.032: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:33.048: Vi2 LCP: O CONFREQ [REQsent] id 8 len 10
Oct 11 10:03:33.048: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:33.048: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:35.064: Vi2 LCP: O CONFREQ [REQsent] id 9 len 10
Oct 11 10:03:35.064: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:35.064: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:37.080: Vi2 LCP: O CONFREQ [REQsent] id 10 len 10
Oct 11 10:03:37.080: Vi2 LCP:    MagicNumber 0x74B224AF (0x050674B224AF)
Oct 11 10:03:37.080: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
Oct 11 10:03:39.096: Vi2 PPP DISC: LCP failed to negotiate
Oct 11 10:03:39.096: PPP: NET STOP send to AAA.
Oct 11 10:03:39.096: Vi2 PPP: No remote authentication for call-out
Oct 11 10:03:39.096: Vi2 LCP: Event[Timeout-] State[REQsent to Stopped]
Oct 11 10:03:39.096: Vi2 LCP: Event[DOWN] State[Stopped to Starting]
Oct 11 10:03:39.096: Vi2 PPP: Phase is DOWN
Oct 11 10:03:40.096: PPP: Alloc Context [A9CC0EC]
Oct 11 10:03:40.096: ppp170 PPP: Phase is ESTABLISHING
Oct 11 10:03:40.096: Vi2 PPP: Using dialer call direction
Oct 11 10:03:40.096: Vi2 PPP: Treating connection as a callout
Oct 11 10:03:40.096: Vi2 PPP: Session handle[A700002A] Session id[170]
Oct 11 10:03:40.096: Vi2 LCP: Event[OPEN] State[Initial to Starting]
Oct 11 10:03:40.096: Vi2 PPP: No remote authentication for call-out
Oct 11 10:03:40.096: Vi2 LCP: O CONFREQ [Starting] id 1 len 10
Oct 11 10:03:40.096: Vi2 LCP:    MagicNumber 0x74B2775F (0x050674B2775F)
Oct 11 10:03:40.096: Vi2 LCP: Event[UP] State[Starting to REQsent]
Oct 11 10:03:42.104: Vi2 LCP: O CONFREQ [REQsent] id 2 len 10
Oct 11 10:03:42.104: Vi2 LCP:    MagicNumber 0x74B2775F (0x050674B2775F)
Oct 11 10:03:42.104: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]do ual
Oct 11 10:03:44.119: Vi2 LCP: O CONFREQ [REQsent] id 3 len 10
Oct 11 10:03:44.119: Vi2 LCP:    MagicNumber 0x74B2775F (0x050674B2775F)
Oct 11 10:03:44.119: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]l
uall
% Invalid input detected at '^' marker.
Oct 11 10:03:46.135: Vi2 LCP: O CONFREQ [REQsent] id 4 len 10
Oct 11 10:03:46.135: Vi2 LCP:    MagicNumber 0x74B2775F (0x050674B2775F)
Oct 11 10:03:46.135: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]u all
All possible debugging has been turned off
Oct 11 10:03:48.151: Vi2 LCP: O CONFREQ [REQsent] id 5 len 10
Oct 11 10:03:48.151: Vi2 LCP:    MagicNumber 0x74B2775F (0x050674B2775F)
Oct 11 10:03:48.151: Vi2 LCP: Event[Timeout+] State[REQsent to REQsent]
HOSTNAME(config-if)#exit
HOSTNAME(config)#exit
HOSTNAME#
HOSTNAME#
HOSTNAME#
HOSTNAME#
HOSTNAME#
HOSTNAME#
HOSTNAME#
Oct 11 10:03:52.331: %SYS-5-CONFIG_I: Configured from console by alan on console
HOSTNAME#
HOSTNAME#
HOSTNAME#
HOSTNAME#
HOSTNAME#show int dialer
HOSTNAME#show int dialer 0
Dialer0 is up, line protocol is up (spoofing)
  Hardware is Unknown
  Description: ###ADSL - Outside###
  Internet address will be negotiated using IPCP
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Closed, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 1 seconds on reset
  Interface is bound to Vi2
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 06:12:44
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/16 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 42 kilobits/sec
     0 packets input, 0 bytes
     0 packets output, 0 bytes
Bound to:
Virtual-Access2 is up, line protocol is down
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 1020 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP REQsent
  PPPoATM vaccess, cloned from Dialer0
  Vaccess status 0x44
  Bound to ATM0.1 VCD: 1, VPI: 8, VCI: 35, loopback not set
  DTR is pulsed for 5 seconds on reset
  Interface is bound to Di0 (Encapsulation PPP)
  Last clearing of "show interface" counters 06:11:17
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1679 packets output, 20148 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
HOSTNAME#
Dear friends,
Please allow me to join.
The debug outputs suggest that the 887 is sending out LCP messages in PPP frames but it never receives a response. This most probably suggests an encapsulation issue. What exact service is the provider using - PPPoA or PPPoE? If the PPPoA is used, what kind of AAL5 encapsulation should be configured - AAL5MUX like the one here, or AAL5SNAP? Any mismatched option out of these will result into the inability to correctly communicate over the DSL link.
Is it possible to find out these details?
Best regards,
Peter
