04-18-2022 05:40 AM - edited 04-18-2022 05:43 AM
Hello .
I have 1 Fiber optic connection with a ISP Router ZTE F660.
i bridged this router ( F660 ) and connect it to my CISCO 887VA-K9 on FAST ETHERNET PORT 0.
i'm strugling how to configure it to connect to internet . i don't have wan port , only 4 fast ethernet.
My ISP need vlan 80 for pppoe connection ( in attachement configuration on the F660 )
Br,
Max
Solved! Go to Solution.
04-21-2022 08:43 AM
thank your for your assistance.
the correct configuration to use ethernet pppoe client on my case :
is : ( i leave this configuration to help people who are on the same situation.
Current configuration : 4321 bytes
version 15.4
hostname Cisco887_no1
boot-start-marker
boot-end-marker
aqm-register-fnf
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-376923471
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-376923471
revocation-check none
rsakeypair TP-self-signed-376923471
crypto pki certificate chain TP-self-signed-376923471
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33373639 32333437 31301E17 0D313430 39323531 34313035
365A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3337 36393233
34373130 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
D6C7F8DE 64BC5557 B630EDFA 6CAC3ED6 626EF88A 7472FB3D E18F3868 EDB8259A
AD8B6834 397FFFC3 2FCEDA76 D6E1195D 8FFC690C 1B0A562A 4106D469 F2E9B9C7
4F403F76 29CBA035 2FBC4CC3 733F11B1 CAA5792D 238F416D A57637B5 BEE0994A
60648960 B4826D50 AEADB67C 35C41CDB 00BC6FFF A9F36F14 2A9EF5C8 B543E54F
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 16801493 9463A10E 2DECD87C B36B87CD BEA60082 20E24630 1D060355
1D0E0416 04149394 63A10E2D ECD87CB3 6B87CDBE A6008220 E246300D 06092A86
4886F70D 01010505 00038181 00D34C7D 2B5E03B5 12513E80 CABF71BB BDB79BC0
F61786B4 0D8AE2B2 CB1CBEC1 23AE4B2E D9CDCA0A 158C9714 1635C14E C3596FCD
7F1318A7 D7887906 55A4B8DB 27958B3C 323B97CD 86D4CB7F FD1789F2 24A56DC7
B0D81477 BBCFCFA1 CA9A4806 8B631DEA DC0FE7C0 BFB923DF 6913F3AA 1DDF5375
66B483EE 623245F9 433A7207 29
quit
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server <203.97.78.44>
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
ip cef
no ipv6 cef
license udi pid C887VA-K9 sn FGL183923HA
username <router_admin_username> privilege 15 secret 5 ***************************231
controller VDSL 0
no cdp run
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
description LAN interface
switchport access vlan 2
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
description WAN interface
switchport access vlan 10
no ip address
interface Vlan1
description not used
ip tcp adjust-mss 1412
interface Vlan2
description LAN
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Vlan10
description WAN
no ip address
ip nat outside
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username <isp_username> password 0 <isp_password>
ppp ipcp dns request
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 199 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
dialer-list 1 protocol ip permit
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 199 permit ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Br
Max
04-18-2022 06:01 AM
below basic config should work, please test and let us know :
Example :
Interface Gig 0/0 - connected to ISP
interface Gig 0/1 - LAN to your switchto switch
Router config
hostname MYRouter
ip dhcp excluded-address 192.168.10.1 192.168.10.20
ip dhcp pool LANPOOL
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.168.10.1 (this can be 8.8.8.8)
interface GigabitEthernet0/0
no ip address
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/0.80
encapsulation dot1Q 80
interface GigabitEthernet0/1
ip address 192.168.10.1 255.255.255.0
ip nat inside
duplex auto
speed auto
no cdp enable
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxxxx
ppp chap password 0 xxxxxx
ppp pap sent-username xxxxx password 0 xxxxxx
no cdp enable
no ip http server
no ip http secure-server
ip nat inside source list 20 interface dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 20 permit 192.168.10.0 0.0.0.255
04-18-2022 06:25 AM - edited 04-18-2022 07:50 AM
Thank your for your quick reply.
i don't have Gigabit ethernet interface i have only fast ethernet interface and ethernet0.
can't set ip nat oustide on fastethernet interfae.
i tried with ethrnet0 instead of Ggabite and vlan1 for my internet lan :
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
*Apr 18 13:33:32.224: Di1 DDR: ip (s=192.168.1.5, d=8.8.8.8), 100 bytes, outgoing uninteresting (dialer-list 1 not defined).
*Apr 18 13:33:34.224: Di1 DDR: ip (s=192.168.1.5, d=8.8.8.8), 100 bytes, outgoing uninteresting (dialer-list 1 not defined).
*Apr 18 13:33:36.224: Di1 DDR: ip (s=192.168.1.5, d=8.8.8.8), 100 bytes, outgoing uninteresting (dialer-list 1 not defined).
*Apr 18 13:33:38.224: Di1 DDR: ip (s=192.168.1.5, d=8.8.8.8), 100 bytes, outgoing uninteresting (dialer-list 1 not defined).
*Apr 18 13:33:40.224: Di1 DDR: ip (s=192.168.1.5, d=8.8.8.8), 100 bytes, outgoing uninteresting (dialer-list 1 not defined).
Success rate is 0 percent (0/5)
Br
04-18-2022 09:47 AM - edited 04-18-2022 09:48 AM
The configuration provided for reference - make sure you understand and use it to work as expected -
post below information from the router :
show version
show IP interface brief
show run
04-21-2022 08:43 AM
version 15.4
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
quit
import all
lease 0 2
no ip domain lookup
ip cef
no ipv6 cef
controller VDSL 0
no cdp run
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
interface Vlan1
interface Vlan2
description LAN
ip nat inside
interface Vlan10
description WAN
no ip address
ip nat outside
interface Dialer0
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip http server
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
Br
Max
04-20-2022 05:40 AM
Cisco 880VA Series Integrated Services Routers Data Sheet - Cisco
Table 1. Cisco 880VA Series Data Models
Models |
WAN Interface |
LAN Interfaces |
802.11g/n Option |
Integrated Third-Generation (3G) WAN Capabilities |
Integrated ISDN Dial Backup |
Cisco 887VA |
Multimode VDSL2/ |
4-port 10/100-Mbps managed switch |
No |
No |
No |
-> you DO HAVE a WAN port, this is the VDSL/ADSL port
this device is designed to route between the VDSL/ADLS port and the internal switch
I don't think it has L3 capabilities on the switchports
04-21-2022 08:44 AM
thank you for your answer . i do it with fastethernet ports i used vlan .
Br,
Max..
