Highlighted
Beginner
Cisco 887va routing problem
I have a problem with Cisco 887va. It wount route trafic from WS to internet.
If I ping from router to internet it works fine, but no trafic from WS goes to internet. What I'm doing wrong?
Here is running config and ping result;
Building configuration...
Current configuration : 1956 bytes
! Last configuration change at 10:23:26 UTC Fri Aug 23 2013
! NVRAM config last updated at 10:23:27 UTC Fri Aug 23 2013
version 15.1
no service pad
hostname Club
boot-start-marker
boot-end-marker
enable secret 5 ***********************
enable password ***********************
no aaa new-model
memory-size iomem 10
no ip source-route
no ip routing
ip dhcp excluded-address 192.168.0.1 192.168.0.99
ip dhcp excluded-address 192.168.0.200 192.168.0.255
ip dhcp pool 192.168.0.0/24
network 192.168.0.0 255.255.255.0
default-router 192.168.0.254
dns-server 192.168.0.254
lease 5
no ip cef
ip name-server 193.229.0.40
ip name-server 193.229.0.42
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ1715C4XV
controller VDSL 0
operating mode adsl2+
interface Ethernet0
no ip address
no ip route-cache
no fair-queue
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
interface ATM0.100 point-to-point
ip address dhcp
ip nat outside
ip virtual-reassembly in
no ip route-cache
atm route-bridged ip
pvc 0/100
  encapsulation aal5snap
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 192.168.0.254 255.255.255.0
ip nat inside
ip nat enable
no ip route-cache
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface ATM0.100 overload
ip route 0.0.0.0 0.0.0.0 ATM0.100
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
line con 0
no modem enable
line aux 0
line vty 0 4
login
transport input all
end
Club#ping 193.229.0.40
Sending 5, 100-byte ICMP Echos to 193.229.0.40, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/220/1020 ms
Club#ping www.fantec.fi
Translating "www.fantec.fi"...domain server (193.229.0.40) [OK]
Sending 5, 100-byte ICMP Echos to 80.69.161.42, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/20/20 ms
If I turn on IP routing, ping stops working.
Everyone's tags (3)
Content for Community-Ad
