107
Beginner
Cisco 9300
Hello All
I am trying to figure out some compatibility. We have Cisco 9300 switches which support 1gb/2.5/5 throughput.
We are exploring the possibility of using the Dell 540s with the ql41162 NIC that supports 1gb and 10gb. The concern is, can the ql41162 NICs negotiate with the Cisco 9300 switch at the 5gb throughput rate?
To phrase another way, the ql41162 NIC supports 10gb throughput, the 9300 up to 5. Will we be able to get the 5 gb throughput from the switch to the NIC?
Thanks in advance!!!!!!!!!!
1 ACCEPTED SOLUTION
VIP Expert
Re: Cisco 9300
The ql41162 NIC support only 1 and 10. So, in this case, it will negotiate down to 1Gig.
1 REPLY 1
VIP Expert
Re: Cisco 9300
Content for Community-Ad
July's Community Spotlight Awards
