01-25-2023 12:11 PM
Hi All,
Can anyone tell me what the 12x1/10/25g ports on the C9300x-12y-a are actually called?
Do they appear as (say) tengig1/0/1 ?
tia
Solved! Go to Solution.
01-25-2023 02:48 PM
Depends on the firmware version. Older version will depend on what optics is plugged in, for example, if a GLC-SX-MMD is connected to port 1 then the interface will be called Gi1/0/1. Any configuration entered into Ten 1/0/1 or Twe 1/0/1 will not be accepted.
In later 17.x.x, if the same GLC-SX-MMD is connected to port 1, it is fine for the configuration to be entered in Twe 1/0/1.
01-26-2023 02:59 AM
Many thanks
01-25-2023 01:01 PM
That is correct. Since the 9300 is stackable, it starts with 1/0/1, 1/0/2, etc.
01-25-2023 02:48 PM
01-26-2023 02:59 AM
Many thanks
