01-27-2020 12:37 AM
Hello Team,
I have strange issue..
The 9500 is configured as collapse backbone (Distribution & Core) with Stackwise VSS configuraiton..
the strange part is .. we are not able to see packet output on show interface command or uplink port connected to the MPLS network.. but everything is working perfectly..
Cisco IOS XE Software, Version 16.09.01
Solved! Go to Solution.
01-27-2020 06:43 PM
01-27-2020 12:41 AM
01-27-2020 12:54 AM
01-27-2020 08:56 AM
Also, check with your monitoring software vendor to make sure they have the right OID, as theses are newer Cisco switches.
01-27-2020 04:04 PM
01-27-2020 04:11 PM
01-27-2020 06:43 PM
