Cisco ASR1001X load based on license applied
Athiqur Rahman
Looking at the page for the Cisco ASR 1000 series routers, I can see that you have the option of upgrading the router, via licensing, form default 2.5Gbps to higher throughput. So with the FLSA-1X-2.5-5G you can go to 5Gbps.
The question that I have is, if am i am just on the 2.5Gbps license, and i do approach say 2.5Gbps, will I be approacching the 100% load of Router? Do i start to drop packets after this? Will there a metric on the router telling me you are reaching your limit?
Then I apply the FLSA-1X-2.5-5G license, doubling my throughput, doe the load half?
0 Replies 0
