Cisco Auto-QoS on Cisco 4500
Oussama.bachiri
Beginner
Beginner
Hi guys,
i wanted to activate auto-qos on my LAN, but when i get to the C4500 i find that the command auto .... is not accepted
Sh Version :
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.05.03.E RELEASE SOFTWARE (fc1)
is it due to my version ?? i want a confirmation !!
Thanks;;
9 Replies 9
Ian Walker
Beginner
Beginner
so im dead, is there any solution so it can support the auto-qos??
thanks please
educruz
Oussama,
If you can provide a complete "show version", that will help more.
Starting with Cisco Release XE 3.3.0(SG) and 15.1(1)SG, the Catalyst 4500 Series Switch supports the "auto qos srnd4" command.
Kind regards,
Ed
Hi Educurz,
okay here is the sh version all of it :)
i don"t know why is not working!!!!
Thank you Oussama,
Due to Auto Qos having 'set' commands ip routing will need to be enabled globally on the
switch. Have you enabled IP routing globally?
Kind regards,
Ed.
yes it is enabled, so what the problem then check this :
CEG01-SWF-1(config)#interface g2/1
CEG01-SWF-1(config-if)#au
CEG01-SWF-1(config-if)#aut
CEG01-SWF-1(config-if)#auto
CEG01-SWF-1(config-if)#auto?
% Unrecognized command
ubhnetworking
Beginner
Beginner
switch(config)#int g1/1
switch(config-if)#auto ?
  qos  Configure AutoQoS
switch(config-if)#auto qos ?
  classify  Configure classification for untrusted devices
  trust     Trust the DSCP/CoS marking
  video     Configure AutoQoS for video devices
  voip      Configure AutoQoS for VoIP
Its there. I am on a 4510 with WS-X45-SUP8-E running Catalyst 4500 L3 Switch Software (cat4500es8-UNIVERSAL-M), Version 03.03.01.XO RELEASE SOFTWARE
hi ubhen,
here you go
i did it on my switch , i dont understand
i have a c4506-E with a supervisor : WS-X45-SUP7L-E
