friends.. i have this 3560 which was connected to my network and when i tried pinging it over LAN it gave me a time of 80-100Ms on 1GB lan directly connected on wire.. i removed this switch .. formatted it .. and connected 3 PCs to it .. and now again doing a ping and other two users are not using ... still the ping is 8-10Ms on LAN ... i am really not sure what to check as when i am doing a ping with other switches on the network with much more load all are at 1Ms. can you guys help
please see attached pic
Jatinder,
which IOS version are you running on the switches ? Issue a 'show proc' command to list all the processes on your switch. There is a bug affecting older IOS versions (12.x) where the 'Hulc' process shows relatively high CPU utilization, which can lead to 'slow' ping responses. This is a bug and does not affect performance.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCsi78581
my processor utilization is 22%.
IOS : c3560-ipbase-mz.122-35.SE5.bin
any help plz
Found another bug that describes your issue, apparently 26 TAC cases have already been opened for this. No workaround currently...
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtj88011
