Cisco C5548 UP _ very urgent please
qasimkhan1
Hi Guys,
We have recently bought 2 x cisco Nexus C5548 UP switches. they are running firmware code : 5.2(1)N1(4) and I want to upgrade them to 5.2(1)N1(8).
However, when I try to upload a the kickstart file and firmware to the switch  I get the the following error:
est1# copy tftp: bootflash: vrf  management
Enter source filename: n5000-uk9.5.2.1.N1.8a.bin
Enter hostname for the tftp server: 192.168.1.1
Trying to connect to tftp server......
Connection to Server Established.
TFTP get operation failed:Undefined error code (2)
I have tried using Solarwinds tftp server and filezila and get the same problem.
Can some one please help me with this as they need to go in to our DCs early next week.
I will really appreciate your help on this.
i have also attached the running config here even though there is no much there.
please let me know if you require further information?
thanks in advance.
InayathUlla Sharieff
Error code 2:
TFTP Error codes:
Error Codes
   0         Not defined, see error message (if any).
   1         File not found.
   2         Access violation.>>>>>>>>>>>>>>>>>>>>>>>> This is were you are stuck now.
   3         Disk full or allocation exceeded.
   4         Illegal TFTP operation.
   5         Unknown transfer ID.
   6         File already exists.
   7         No such user.
Action:
==>It might be due to wrong path or filename.
==> Download tftp32
==> Direct the file properly on the tftp server.( Check the file size on the cisco website and match the file size which is been downloaded on the pc/server it should match).
==>Ping the tftp server with 100 packets and make sure no drops.
==>Access the file from ther server (Make sure exact name is provided).
Error code 2:
TFTP Error codes:
Error Codes
   1         File not found.
   7         No such user.
Action:
==> Download tftp32
Thanks Insharie,
I have followed all the steps correctly and to be honest I have upgraded nexus switches before as well but this time I am not having any luck with it. However, I have just noticed that the file size on the Cisco download web is 167.58 MB  but on my PC it is showing it as 171614KB (172.614MB). Do you think this could be the problem? if so how can I fix that?
Also one thing I forgot to mention was that it starts uploading the file but when it gets to the last bits it stops and gives that error.
Many thanks for you help in advance?
I thought I would let you know that it was a problem with the tftp servers types that I was using I think. as I have just tried it with 3cdaemon/FTP  and it worked.
thanks for your help though.
