Cisco C9500-48Y4C
marzi
Hi all
I 've two Cisco C9500-48Y4C stacked in stackwise virtual mode.
The release onboard is the 17.12.4 (latest suggested).
My problem is that the dual-active detection port are stucked in shutdown.
Dual-Active-Detection Configuration:
Switch Dad port Status
1 TwentyFiveGigE1/0/48 down
2 TwentyFiveGigE2/0/48 down
I tried different mode to resolve the issue, but I had no solution, p.es.: I unconfigured the above ports, I done shut an no shut,
I've reload many times the devices but nothing
Does anyone had a tip for me ?
Fabrizio
Mark Elsen
    - Check logs on the 9500 after shut/no shut
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
  M.
       Beauty and terror
      Just keep going
       No feeling is final
CSCO11269440
Please provide the interface setting parameters and provide the SFP status to check.
