03-08-2015 06:47 PM - edited 03-07-2019 11:00 PM
Hello!!
Can i use 10Gb Link between a Cisco Catalyst 6500 whit a Cisco Catalyst 6900 Series 8-Port 10 Gigabit Ethernet Fiber Module (WS-X6908-10G-2T) card and 10GBASE-SR X2 Fiber port, and . And in the other side use a Cisco Catalyst 2960X-48FPD-L (have two SFP+ bays) whit SFP-10G-SR= (multimode fiber)
this solutions works???
another question:
WS-X6908-10G-2T card comes equipped with DFC4. What mean that? requiere another slot in a 6500 chassis??
thanks
Solved! Go to Solution.
03-08-2015 08:02 PM
Q1:- yes it should work.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-series-switches/data_sheet_c78-648212.html
2)
Answer: No DFC4 is the sub-module which would sit on the line card WS-X6908-10G-2T. It doesnt require any spare slot.
WS-X6908-10G-2T: comes equipped with DFC4 for distributed forwarding, supporting 256K forwarding entries, increased ACL entries to 64K, increased Netflow entries to 512K, and increased IPv4 forwarding speed to 60 Mpps
03-08-2015 08:02 PM
2)
