Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Catalyst 3650 IOS Recovery Not Working From Flash nor From USB
ZeeshanMarwat
Hi All
Can you please check and let me know what the problem is. After a power failure, the switch got stuck in ROM monitor and unable to boot from flash or USB below are the errors.
From Flash:
switch: boot flash:packages.conf
Getting rest of image
Reading full image into memory...Check base package header ...: done = 16384
Autoboot process terminated...
Reading full base package into memory...
Error loading "flash:packages.conf"
Boot process failed...
From USB:
switch: boot usbflash0:/cat3k_caa-universalk9.16.06.08.SPA.bin
usbflash0:/cat3k_caa-universalk9.16.06.08.SPA.bin: unknown error
usbflash0:/cat3k_caa-universalk9.16.06.08.SPA.bin: bad/non-bootable bundle file
Error loading "usbflash0:/cat3k_caa-universalk9.16.06.08.SPA.bin"
Interrupt within 5 seconds to abort boot process.
Boot process terminated.
Zeeshan Khan
Mohsin Alam
Can you try :
Rommon> reset
Then share the output of:
set
Dir flash:
more flash:packages.conf
## Make sure to mark post as helpful, If it resolved your issue. ##
