Cisco Catalyst 4507R-E Switch connection problem
Hi all!
I have a problem with dot1q connection between Cisco Catalyst 4507R-E Switch (WS-X4516 - Supervisor Engine V )and Fortigate 60M firewall.
On Fortigate 60M side I configured dot1q VLANs. On Cisco side I configured trunk port on classic way:
interface GigabitEthernet3/1
switchport mode trunk
result is:
GigabitEthernet3/1 is down, line protocol is down
There was't a problems with similar connections (dot1q) between Fortigate 60M and other switches, and between Cisco Catalyst 4507R-E Switch and other switches.
Best regards,
Miroslav Petkovic
glen.grant
If its down/down that is a physical layer problem . Make sure you are using the correct connect cables.
I made dot1q connection between Cisco Catalyst 4507R-E Switch and 3com switch (Baseline Switch 2924-SFP Plus), and everything was correct.
But I still have a problem with dot1q connection between Cisco Catalyst 4507R-E Switch (WS-X4516 - Supervisor Engine V ), (by using same cable and port) and Fortigate 60M firewall.
It seems, there isn't layer 1 problem.
