02-13-2023 05:12 PM
The Cisco Catalyst 6509-E is equipped with a WS-X6816-10GE module.
Four of the modules have been switched to the GX2-31192-LRC SFP Transceiver err-disable state.
The error log is as follows:
Feb 10 19:44:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.117.37.219
Feb 11 21:38:59: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.201.1 on Vlan910 from FULL to DOWN, Neighbor Down: Dead timer expired
Feb 11 21:39:05: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.203.1 on Vlan930 from FULL to DOWN, Neighbor Down: Dead timer expired
Feb 11 21:44:58: %CONST_DIAG-3-HM_PORT_TEST_FAIL: Module 2 TestNonDisruptiveLoopback Port(s)[1-4] failed. System operation continues.
Feb 11 21:44:58: %HA_EM-6-LOG: Mandatory.go_nondislp.tcl: GOLD EEM TCL policy for TestNonDisruptiveLoopback
Feb 11 21:44:58: %DATACORRUPTION-1-DATAINCONSISTENCY: copy error, -PC= 0x84FB214z
-Traceback= 67237B4z AF4B36Cz 6645414z 84FB214z 84FB324z 84B4CACz 84C8AE8z 84CC63Cz 84A90E0z 84C6980z 84E6D98z 84C8AE8z 84CC63Cz 84A90E0z 84AFDD0z 84ECF68z
-Traceback= 67237B4z AF4B36Cz 6645414z 84FB214z 84FB324z 84B7060z 84C8AE8z 84CC63Cz 84A90E0z 84C6980z 84E6D98z 84C8AE8z 84CC63Cz 84A90E0z 84AFDD0z 84ECF68z
Feb 11 21:44:58: %DATACORRUPTION-1-DATAINCONSISTENCY: copy error, -PC= 0x84FA038z
-Traceback= 67237B4z AF4B36Cz 6645414z 84FA038z 84EC10Cz 85046DCz 8504A48z 8505FD4z 84C8AE8z 84CC63Cz 84A90E0z 84C6980z 84E6D98z 84C8AE8z 84CC63Cz 84A90E0z
Feb 11 21:44:58: %PM-4-ERR_DISABLE: diagnostics error detected on Te2/1, putting Te2/1 in err-disable state
Feb 11 21:44:58: %PM-4-ERR_DISABLE: diagnostics error detected on Te2/2, putting Te2/2 in err-disable state
Feb 11 21:44:58: %PM-4-ERR_DISABLE: diagnostics error detected on Te2/3, putting Te2/3 in err-disable state
Feb 11 21:44:58: %PM-4-ERR_DISABLE: diagnostics error detected on Te2/4, putting Te2/4 in err-disable state
Feb 11 21:44:58: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1, changed state to down
Feb 11 21:44:58: %LINK-3-UPDOWN: Interface Vlan910, changed state to down
Feb 11 21:44:58: %LINK-3-UPDOWN: Interface Port-channel10, changed state to down
Feb 11 21:44:58: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/2, changed state to down
Feb 11 21:44:58: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/3, changed state to down
Feb 11 21:44:58: %LINK-3-UPDOWN: Interface Vlan930, changed state to down
Feb 11 21:44:58: %LINK-3-UPDOWN: Interface Port-channel30, changed state to down
Feb 11 21:44:58: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/4, changed state to down
Feb 11 21:44:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1, changed state to down
Feb 11 21:44:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/2, changed state to down
Feb 11 21:44:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel10, changed state to down
Feb 11 21:44:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/3, changed state to down
Feb 11 21:44:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/4, changed state to down
Feb 11 21:44:58: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel30, changed state to down
Feb 11 21:44:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan910, changed state to down
Feb 11 21:44:59: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan930, changed state to down
Feb 11 21:44:58: %PM-STBY-4-ERR_DISABLE: diagnostics error detected on Te2/1, putting Te2/1 in err-disable state
Feb 11 21:44:58: %PM-STBY-4-ERR_DISABLE: diagnostics error detected on Te2/2, putting Te2/2 in err-disable state
Feb 11 21:44:58: %PM-STBY-4-ERR_DISABLE: diagnostics error detected on Te2/3, putting Te2/3 in err-disable state
Feb 11 21:44:58: %PM-STBY-4-ERR_DISABLE: diagnostics error detected on Te2/4, putting Te2/4 in err-disable state
The same symptoms occur when replacing with a new GX2-31192-LRC SFP Transceiver.
Feb 13 14:27:40: %CONST_DIAG-3-HM_PORT_TEST_FAIL: Module 2 TestNonDisruptiveLoopback Port(s)[1] failed. System operation continues.
Feb 13 14:27:40: %%HA_EM-6-LOG: Mandatory.go_nondislp.tcl: GOLD EEM TCL policy for TestNonDisruptiveLoopback
Feb 13 14:27:40: %PM-4-ERR_DISABLE: diagnostics error detected on Te2/1, putting Te2/1 in err-disable state
Feb 13 14:27:40: Interface Vlan910, changed state to down
Feb 13 14:27:40: %LINK-3-UPDOWN: Interface Port-channel10, changed state to down
Feb 13 14:27:40: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1, changed state to down
Feb 13 14:27:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1, changed state to down
Feb 13 14:27:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel10, changed state to down
Feb 13 14:27:40: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan910, changed state to down
Feb 13 14:27:40: %PM-STBY-4-ERR_DISABLE: diagnostics error detected on Te2/1, putting Te2/1 in err-disable state
What could be the cause?
02-13-2023 05:53 PM
The line card looks to be cooked.
Re-seat the line card and post the "sh logs" after the re-seat. It will determine if the line card has failed POST or not.
