Cisco Catalyst 9500 tacacs key
beta_admin66
I get error message when configuring the key of the Tacacs server on the Cisco Catalyst 9500, first used the Password Type 7:
WARNING: Command has been added to the configuration using a type 5 password. However, type 5 passwords will soon be deprecated. Migrate to a supported password type.
Then I changed the password type to 6:
Host name (config-server-tacacs) #key 6 xxxx
% Invalid encrypted key: xxxx
If I set the passway location Type to 0, I will still receive this error message when I start the switch.
Can you help?
5 Replies 5
Mark Malone
have you tried to set it this way as an option does it work ?
aaa group server tacacs+ xtacacs
server-private 172.x.x.x key 7 1214402D204E045D287C7275607406583642422678
server-private 172.x.x.x key 7 0009563C361E035F0D761A135A58215C235F4D2304
ip tacacs source-interface x
I have inverted these commands:
tacacs server xxx
 address ipv4 xxx
 key xxx
WARNING: Command has been added to the configuration using a type 7 password. However, type 7 passwords will soon be deprecated. Migrate to a supported password type
Also I entered this commands:
server-private ip-address key 7 xxx
Also I receive this error-message:
Im just wondering should be under AAA like mine we had issues like that on newer software on 4ks and 3ks too , its all unified software IOS-XE so should work like that
alot of tacacs commands were deprecated in newer releases , worth a shot
aaa new-model
ip tacacs source-interface Vlan2225
aaa authentication login default group xtacacs local enable
aaa authentication enable default group xtacacs enable
aaa authorization exec default group xtacacs local
aaa accounting exec default start-stop group xtacacs
aaa accounting commands 0 default start-stop group xtacacs
aaa accounting commands 1 default start-stop group xtacacs
aaa accounting commands 15 default start-stop group xtacacs
aaa accounting network default start-stop group xtacacs
aaa accounting connection default start-stop group xtacacs
aaa accounting system default start-stop group xtacacs
how can the bug be fixed?
Thank you.
Its not a bug its deprecated code , its moved on , it happens now and again they change it up
If you think its bug open a case with Cisco TAC but the message is telling you the code is not valid your trying to apply anymore
