Join Customer Connection to register!
907
tjacobjames
Beginner
Cisco Catalyst Express 500 Series Switches
Can we force the Gigabit Ethernet port to be 1000 full duplex in Cisco Catalyst Express 500 series?
3 REPLIES 3
mohammedmahmoud
Advisor
davidmeiker
Beginner
Greetings
The CE500 have a CLI Mode, Yes it have! and you can force your interface!
But In my humble opinion I think its a Emulation of the CLI
When you do all the configuration in the SW, just type in you internet explorer.."http:// + IP Swithc + /exec" for example "http://192.168.10.2/exec"
And you can emulate the CLI in the CE500.
Hi Jose Quintero...
i try change the configuration the port in the switch catalyst express 500, i need disable switchport port-security, a try with http://10.1.1.1/exec and save configuration with wr command, if a check the configuration de port is correct but i reboot the switch and check the configuration the port appear the switchport port-security configuration again.
do you know solve this??
thk and regards!!!
