10-05-2023 06:07 AM
Dear All, we have 9 POE Yealink phones connected to the switch: do you you think is worth/possible/not possible to add them all into a LAG?
Solved! Go to Solution.
10-05-2023 09:14 AM
10-05-2023 06:41 AM
- Depends on what you mean, the local network connection/loop can't do LAG because it's single ,
M.
10-05-2023 09:14 AM
