Cisco CE500 restarting.
mano.hernandez
Beginner
Beginner
One of our buildings has a 24-port poe CE500 that restarts about 2 times a day. I've swapped it out with another CE500 and also swapped out the UPS, however I am still getting reboots once a day. Do you know what would be causing a reboot? I've checked errors but I don't see anything out of the ordinary.
Islam Nadim
Beginner
Beginner
Can you share the logs? Also, try installing a Syslog Server like 3CDaemon and store the logs in it .. You may be able to find the cause.
Also, can you share the output of show version?
Best Regards,
Islam M. Nadim.
Recognize Your Peers
