Cisco IOSvL2 console CLI does not appear.
        I am using CiscovL2 for studying QoS. I am able to install the image in GNS3 successfully. But when I open the console the CLI does not appear. The attached snapshot gives a better idea. Any help regarding this will be appreciated. Thanks in advance.
8 Replies 8
pieterh
I guess you followed this document ?
did you power on the appliance ?  right click on the appliance and click Start
Yes, I have followed the same document. Even after powering the appliances the CLI does not appear.
your image does not look like the GNS3 console
do you right click and select console?
Yes, I have done right click and opened the console. I running GNS3 on Linux that's why the console looks different.
can you post a screenshot of the GNS3 terminal settings you are using ?
Yes, now everything seems to be working correctly. Attaching Screenshot of the Console.
J-25
What fixed this for you? I haven't seen any fix actions below and I'm having the same problem.
you better post this as a new thread (the current is more than a year old)
- describe what is happening and what not, not just "same problem"
- did you power on the device?
   be patient it may take some time before output appears when the "device" is booting.
