09-17-2021 01:15 AM
Whenever I try to boot ISR 4451 using TFTP It gets boot but after some time It gets reboot automatically.
*Jan 1 21:13:39.583: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jan 1 21:13:40.004: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jan 1 21:13:40.042: %ESG_THROUGHPUT-6-LEVEL: Throughput level has been set to 1000000 kbps
*Jan 1 21:13:47.012: pak_debug_init: Successfully initialized pak debug trace buffer
*Jan 1 21:13:48.923: adsl_ifmib_init
*Jan 1 21:13:48.950: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jan 1 21:13:48.950: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jan 1 21:13:48.951: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jan 1 21:13:48.951: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jan 1 21:13:50.972: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jan 1 21:13:31.117: %CMRP-3-PFU_MISSING:cmand: The platform does not detect a power supply in slot 1
*Jan 1 21:13:41.967: %CMLIB-6-THROUGHPUT_VALUE:cmand: Throughput license found, throughput set to 1000000 kbps
*Jan 1 21:13:42.929: %CPPHA-7-START:cpp_ha: CPP 0 preparing ucode
*Jan 1 21:13:42.941: %CPPHA-7-START:cpp_ha: CPP 0 startup init
*Jan 1 21:13:46.416: %EVUTIL-6-PREREQUISITE:cmcc: Preferred library is absent
*Jan 1 21:13:46.970: %EVUTIL-6-PREREQUISITE:cmcc: Preferred library is absent
*Jan 1 21:13:48.014: %EVUTIL-6-PREREQUISITE:cmcc: Preferred library is absent
*Jan 1 21:13:51.045: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jan 1 21:13:51.046: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jan 1 21:13:51.046: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jan 1 21:13:51.046: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jan 1 21:13:52.908: %SYS-4-CONFIG_NEWER: Configuration from version 16.3 may not be correctly understood
*Jan 1 21:13:53.910: %SYS-5-CONFIG_I: Configured from memory by console
*Jan 1 21:13:53.912: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jan 1 21:13:53.914: %SPA_OIR-6-OFFLINECARD: SPA (ISR4451-X-4x1GE) offline in subslot 0/0
*Jan 1 21:13:53.915: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jan 1 21:13:53.915: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jan 1 21:13:53.916: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jan 1 21:13:53.916: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jan 1 21:13:53.917: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jan 1 21:13:53.917: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jan 1 21:13:53.917: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 2
*Jan 1 21:13:53.945: %SPA-3-ENVMON_NOT_MONITORED:iomd: Environmental monitoring is not enabled for ISR4451-X-4x1GE[0/0]
*Jan 1 21:13:55.693: new extended attributes received from iomd(slot 0 bay 0 board 0)
*Jan 1 21:13:55.693: %IOSXE_OIR-6-SOFT_RELOADSPA: SPA(ISR4451-X-4x1GE) reloaded on subslot 0/0
*Jan 1 21:13:55.694: %SPA_OIR-6-OFFLINECARD: SPA (ISR4451-X-4x1GE) offline in subslot 0/0
*Jan 1 21:13:58.489: %CPPHA-3-INITFAIL:cpp_ha: CPP 0 initialization failed - startup init (0x43)
*Jan 1 21:13:58.489: %CPPHA-3-INITFAIL:cpp_ha: CPP 0 initialization failed - start CPP (0x43)
*Jan 1 21:13:58.546: %PMAN-3-PROCHOLDDOWN:pman.sh: The process cpp_driver has been helddown (rc 255)
*Jan 1 21:13:58.594: %PMAN-0-PROCFAILCRIT:pvp.sh: A critical process cpp_driver has failed (rc 255)
*Jan 1 21:14:00.696: %SPA-3-ENVMON_NOT_MONITORED:iomd: Environmental monitoring is not enabled for ISR4451-X-4x1GE[0/0]
*Jan 1 21:14:02.626: %IOSXE-6-PLATFORM:cpp_cdm: Shutting down CPP MDM while client(s) still connected
*Jan 1 21:14:02.680: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
*Jan 1 21:14:02.926: %SPA_OIR-6-ONLINECARD: SPA (ISR4451-X-4x1GE) online in subslot 0/0
*Jan 1 21:14:04.916: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Jan 1 21:14:04.923: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Jan 1 21:14:04.924: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed state to down
*Jan 1 21:14:04.925: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/3, changed state to down
*Jan 1 21:14:06.961: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Jan 1 21:14:07.961: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Jan 1 21:14:12.509: %PMAN-3-PROCHOLDDOWN:pman.sh: The process cpp_ha_top_level_server has been helddown (rc 139)
*Jan 1 21:14:13.663: %PMAN-5-EXITACTION:pvp.sh: Process manager is exiting: critical process fault, cpp_driver, fp_0_0, rc=255
*Jan 1 21:14:14.683: %PMAN-5-EXITACTION:pvp.sh: Process manager is exiting: reload fru action requested
*Jan 1 21:14:14.685: %PMAN-5-EXITACTION:pvp.sh: Process manager is exiting: reload fru action requested
*Jan 1 21:14:14.781: %PMAN-5-EXITACTION:pvp.sh: Process manager is exiting: reload fru action requestedJan 1 21:14:47.908 R0/0: %PMAN-5-EXITACTION: Process manager is exiting: reload fru action requested
Initializing Hardware ...
System integrity status: 00000610
Rom image verified correctly
System Bootstrap, Version 15.4(3r)S, RELEASE SOFTWARE
Copyright (c) 1994-2014 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
Cisco ISR4451-X/K9 platform with 4194304 Kbytes of main memory
rommon 1 >
rommon 1 >
rommon 1 >
rommon 1 >
09-17-2021 02:49 AM
found below 3 bug reports. try with upgrading the OS.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuo29770/?rfs=iqvred
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCve39622/?rfs=iqvred
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz41077/?rfs=iqvred
Good luck
KB
09-17-2021 04:03 AM
What firmware is the router running on?
Raise a TAC Case and get them to confirm if this is CSCve39622.
09-17-2021 07:08 AM
isr4400-universalk9.16.03.05.SPA.bin
This firmware version i have been using. I have 2 Router of ISR 4451 first one is working fine with this version but second one having this issue.
09-17-2021 04:29 PM
If the router can get into ROMMON, post the complete output to the following commands:
Console into the router and reboot the router. Post the entire bootup process. We want to see what is going on when the router boots up.
09-18-2021 04:33 AM
dear rebooting issue have fixed. I just updated my RAMs and reboot the router. now it is working but after some it shows this error.
*Sep 18 11:32:14.591: %CMRP-3-CHASSIS_MONITOR_ONLINE_TIME_EXCEEDED:cmand: Reloading F0 because it has failed to come online
Kindly guide what to do next?
09-18-2021 06:19 AM
09-18-2021 08:20 PM
@ImOwaisAB wrote:
I find something in "show plateform" command kindly have a look and elaborate the reason behind it. I have attached the image.
I cannot provide an "elaborate the reason behind it" because the information provided is being "drip fed".
I am waiting for someone to get serious and provide the information being asked before I will do anything.
An alternative is to raise a TAC Case.
