cisco logging
tedauction
Hello, I want to create a log of commands that I enter into my switch and router.
I have used the following command:
logging buffered 128000 informational
However when I am ready to view my past commands, I enter "show logging" but I do not see the past commands.
What am I doing wrong here ?
Thank you for any help.
luckymike33
you can use the following to enable the features you want:
archive
log config
logging enable
notify syslog
hidekeys
view the command history using 'show archive log config all'
Note
 - notify syslog  - generates a syslog message
- this only logs config commands, if you want to log all commands - use Tacacs, and you can see who entered what.
Mike
luckymike33
archive
log config
logging enable
notify syslog
hidekeys
Note
Mike
