11-24-2019 06:51 AM
Greetings,
Can we propose for a hotel infrastructure Cisco Meraki MS120 24/48 port switches instead of Cisco 220 POE 24/48 port switches. as access switches floor wise to provide data network, wireless and CCTV connectivity.
Total users around 500.
11-24-2019 08:01 AM
Look this document, i hope that it can help you: https://www.aventissystems.com/v/vspfiles/downloadables/aventis-systems-meraki-switches-comparison.pdf
11-24-2019 08:19 AM
Hello
Yes you can however please note Meraki devices are cloud based administrated so if you are not using any Meraki FW (MX) in your network design then you will need to open up ports on your existing perimeter FW allow this access
11-24-2019 11:16 AM
Its complete new network deplyment.
Is it necessary or better to deploy all meraki solution or can we deploy meraki only for access switches, wireless& cctv and cisco for core switch and router.
11-24-2019 08:23 AM
do you need/want cloud based management ?
11-24-2019 11:13 AM
Ok with both ways of management.
Main thing is whether cisco 220 or meraki 120 would be a more cost effective solution.
11-24-2019 12:26 PM
