02-14-2022 10:16 AM
Hi, the ZR-SFP transceiver are supposed to have a diagnostic feature where I can view the dB loss/power/temp?
but when I am trying to look for the DOM (Digital Diagnostics Monitoring) it does not show me the desired results ?
I want to know if the Switch is capable of reading the DOM ? Any input will be helpful. Thanks
02-14-2022 10:35 AM
which SFP is that exactly ? The SFP-10G-ZR ?
Is that an OEM (Cisco) SFP, or a third party one ?
02-16-2022 08:51 AM
Its SFP-10g-ZR 80km, Its a third party optics but I have tested it on other switches and it did work just fine just not with ME3600 switch.
02-14-2022 10:47 AM
There is a bug related to some SFPs associated to ME3600. take a look inline
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy16460?reffering_site=dumpcr
Leonardo
02-16-2022 09:31 AM
Hi Leonardo,
Thanks for sharing the details, I looked into the link but it does not specifies the perfect solution, the version I have is 15.5(3)S2.2. which it says is a fixed release after the bug. Is there any other solution to it ?
02-24-2022 08:05 PM
Anyone has any updates on the above issue, Can you please help ??
02-25-2022 07:51 AM
Hello palashgoyal21
Have you verified the level of license on your device? to run the tengig interfaces on the Me-3600X devices we need to activate the 10GEupgarde license on the device.
02-27-2022 07:48 PM
Hi Leonardo,
Thanks for your response.
The Me-3600X has active License for the 10GEupgarde on the device. I have other SFP works fine on the same machine, but just not the SFP-10ge-ZR, I have link lights but unable to see the DOM, I cant use it since I have to adjust the link budget according to Tx/Rx powers. (The same SFP shows DOM on my NEXUS9K switch )
Please suggest what can be a possible fix for this.
