06-27-2022 10:18 PM
Hello ,
We have the following network setup as a minimal multicast testing environment. Please don't bother about 194.x.x.x ip addresses used in the intranet.
Udp sender host can send the udp multicast to the interface ethernet 1/36 and Udp receiver host can successfuly join the multicast group, but udp multicasts are never reaching either Vlan401 and Udp receiver host.
Thank You For Your Help
Solved! Go to Solution.
06-28-2022 02:04 AM
Not sure what software you are using to test with but check the TTL of the packets.
It obviously needs to be > 1 if you are routing between directly connected subnets.
Jon
06-27-2022 11:04 PM
Some more information and a correction
Correction : The interface address of 1/36 is actually 194.0.142.147/28 ( not 192.142.0.146 ) . This a typo error of me. Actually its correct
The version of the switch is : nxos.9.2.2.bin
06-28-2022 12:18 AM
I have changed the interface 1/36 to switchport and included to VLAN 401. And i have set the sender ip address from that VLAN 401.
Multicasting works fine if everthing in the same VLAN.
06-28-2022 02:04 AM
Jon
06-28-2022 02:39 AM
This is special testing application written in Python . I have a sender application and a receiver application. I don't know how to check TTL.
The sender application is sending 20 bytes of test packet from the port 5007 to the receiver every 0.5 seconds continuously.
06-28-2022 02:48 AM
You could capture the packets to see what the TTL is set to.
Jon
07-01-2022 02:08 AM
Yes , you are correct
I have modified the python multicast sender application code as below.
MULTICAST_TTL = 5
sock.setsockopt(socket.IPPROTO, IP,socket.IP_MULTICAST_TTL, MULTICAST_TTL)
and it worked !
06-28-2022 01:06 AM
Do you have multicast routing enabled globally? I suspect not. Depending on the platform, that will be either "ip multicast-routing" or "ip multicast-routing distributed".
06-28-2022 02:32 AM
I don't know how to set ip multicast-routing or ip multicast-routing distributed in the nx-os nxos.9.2.2.bin. It looks that this version of OS doesn't have these global commands. The only global multicast command that is active is :
ip multicast multipath s-g-hash next-hop-based
06-28-2022 05:23 AM
You did say Nexus, but somehow I missed that. First, you need "feature pim" in global config. This guide says 9K, but I suspect it should be relevant to the 3548 depending on the version. I have done multicast in various routers and switches, but not in a Nexus to this point.
06-29-2022 09:04 AM
Two features are enabled in the 3548
- Feature interface-vlan
- Feature pim
