Highlighted
Beginner
Cisco Nexus 9504 EPLD Upgrade
I have a Nexus currently running on code 7.0(3)I7(4). I performed an EPLD upgrade on the required modules. The fabric modules were successfully upgraded. The line cards (N9K-X97160YC-EX) was successfully upgraded too. However, when I ran the  command "show version module 1 epld". The module is still running on the old version. I would like to know the cause of such behavior. On the other hand, the aforesaid modules failed the diagnostics as well. Moreover, What would be a better practice for EPLD upgrades on the nexus 9504?
10 REPLIES 10
Highlighted
VIP Mentor
Re: Cisco Nexus 9504 EPLD Upgrade
what is the output of:
show install epld status
Highlighted
Beginner
Please see below output for the EPLD status. You may notice the EPLD upgrade on module 1 is successful and the current version is 0x11. however, when you run "show version module 1 epld" command, the IO FPGA on module 1 is running the old version.
1) Module 1 upgraded on Wed Sep ......................
EPLD Install Image: EPLD image file 7.0.3.I7.4. built on Thu Jun 14 01:32:49 2018
Status: EPLD Upgrade was Successful
EPLD Curr Ver Old Ver
IO FPGA 0x11 0x3
EPLD Device Version
MI FPGA 0x4
IO FPGA 0x3
Highlighted
VIP Mentor
What if you reload the module, is it still showing the old version ?
Highlighted
Beginner
I tried reloading the module, still shows the old version. I went back and forth with different EPLD images. The EPLD upgrade is successful. But, the new version doesn't apply to the affected module.
Highlighted
VIP Mentor
odd. Sounds like some sort of bug. What does:
show install all impact epld x
show (where x is the image name) ?
Highlighted
Beginner
Shows an upgrade is required even after an EPLD upgrade .I didn't have the same issue with the fabric modules/
show install all impact epld bootflash:n9000-epld.7.0.3.I7.4.img
Retrieving EPLD versions.... Please wait.
Images will be upgraded according to following table:
Module Type EPLD Running-Version New-Version Upg-Required
1 LC MI FPGA 0x04 0x04 No
1 LC IO FPGA 0x03 0x11 Yes
2 LC MI FPGA 0x04 0x04 No
2 LC IO FPGA 0x03 0x11 Yes
22 FM IO FPGA 0x14 0x14 No
23 FM IO FPGA 0x14 0x14 No
24 FM IO FPGA 0x14 0x14 No
26 FM IO FPGA 0x14 0x14 No
27 SUP IO FPGA 0x27 0x27 No
28 SUP IO FPGA 0x27 0x27 No
29 SC IO FPGA 0x20 0x20 No
30 SC IO FPGA 0x20 0x20 No
Highlighted
VIP Mentor
check if:
indicates whether the BIOS needs an upgrade...
Highlighted
Beginner
Doesn't require an upgrade
Module Image Running-Version(pri:alt) New-Version Upg-Required
1 lcn9k 7.0(3)I7(4) 7.0(3)I7(4) no
1 bios v03.41(08/07/2017):v03.41(08/07/2017) v03.41(08/07/2017) no
2 lcn9k 7.0(3)I7(4) 7.0(3)I7(4) no
2 bios v03.41(08/07/2017):v03.41(08/07/2017) v03.41(08/07/2017) no
22 lcn9k 7.0(3)I7(4) 7.0(3)I7(4) no
22 bios v03.41(08/07/2017):v03.28(04/12/2016) v03.41(08/07/2017) no
23 lcn9k 7.0(3)I7(4) 7.0(3)I7(4) no
23 bios v03.41(08/07/2017):v03.28(04/12/2016) v03.41(08/07/2017) no
24 lcn9k 7.0(3)I7(4) 7.0(3)I7(4) no
24 bios v03.41(08/07/2017):v03.28(04/12/2016) v03.41(08/07/2017) no
26 lcn9k 7.0(3)I7(4) 7.0(3)I7(4) no
26 bios v03.41(08/07/2017):v03.28(04/12/2016) v03.41(08/07/2017) no
27 nxos 7.0(3)I7(4) 7.0(3)I7(4) no
27 bios v08.32(10/18/2016):v08.29(05/13/2016) v08.32(10/18/2016) no
28 nxos 7.0(3)I7(4) 7.0(3)I7(4) no
28 bios v08.32(10/18/2016):v08.29(05/13/2016) v08.32(10/18/2016) no
29 lcn9k 7.0(3)I7(4) 7.0(3)I7(4) no
29 bios v01.48(00:v01.48(00 v01.48(00 no
30 lcn9k 7.0(3)I7(4) 7.0(3)I7(4) no
30 bios v01.48(00:v01.48(00 v01.48(00 no
Highlighted
VIP Mentor
what is the exact model of line card(s) that you want to upgrade ?
Highlighted
Beginner
N9K-X97160YC-EX     |  48x10/25G + 4x40/100G Ethernet Module
Content for Community-Ad
