06-07-2011 12:14 AM - edited 03-06-2019 05:21 PM
The N2K-C2232PF-10GE has 16 Fabric Extender Trancievers can these be used to connect to servers as well.?
06-07-2011 07:26 AM
The Nexus 2232 can support 32 10GE connection to servers and FEX fabric interfaces to the N5Ks.
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps10110/data_sheet_c78-507093.html
jerry
06-08-2011 02:01 AM
thanks.
but the link still does not tell me if i can use the FEX fabric interfaces to connect servers.
06-09-2011 06:19 PM
I got confused when you said 16 Fabric Extender Tranceivers in the original post. No, you cannot use the FEX fabric interfaces to connect servers. It is for connections to N5K/N7K.
HTH,
jerry
