Cisco Nexus N9K SSH
vondoom2
Is it possible to ssh from a Test Workstation through the Cisco Nexus device and to a desired device I wish to communicate with?
Example, I have a test workstation (Cisco Catalyst 3850) that is connected to my Nexus Switch (which is in an enclosed fixture) that is connected to other servers.  And we will use one server as an example and give it the ip address 192.168.35.3/24 and the local workstation ip address is 192.168.35.121/24.  Would I be able to ssh right through from the workstation to the server or would I have ssh to the Nexus switch first and then the server.  Also, if you could be so kind as to I would need to configure/assign aside from activating 'feature ssh', that has been initiated.
Thank you.
balaji.bandi
as long they are in the same subnet, you are able to directly  SSH to the nexus device.
follow the below guide to enable SSH : (just for reference)
https://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli_rel_4_1/Cisco_Nexus_5000_Series_Switch_CLI_Software_Configuration_Guide_chapter20.html
BB
