Cisco nexus switch vlans are not shown on spanning-tree and vlan l2 is down
Saed Eldin
Dear
I have two disco switches  N5K which run VPC and connected together to non-vss Cisco switches 6500. The Port channels between 6k and N5k are up , but i cannot see any vlans under spanning-tree also if i did show interface  trunk we got all vlans under err-disable. We have enable only
Please check attached.
Mark Malone
Hi , why are there no vlans allowed/configured on the vpc peer-link between the 5ks ?
vlans are usually allowed on this trunk as example below from one of my dcs , can you post the show vlan from each switch and show vpc brief as well please
interface port-channel11
  description VPC Peer link to xxxxxxxxxxxx
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 2,10-11,17-18,20,28,31,33-34,36-39
  switchport trunk allowed vlan add 48,50,64-67,70,72,74,76,78,80,90-108
  switchport trunk allowed vlan add 112,226,400,431,490,1226,2224
  spanning-tree port type network
  logging event port link-status
  logging event port trunk-status
  vpc peer-link
Mark
Thanks so much for your help.
I will test your recommendation above and i will let you know today.
