03-26-2012 12:31 PM - edited 03-07-2019 05:47 AM
Hello Experts,
Can some please take at the attached configs and help me determine why I can't get the port channels to come up the switches.?
Cheers
Carlton
03-26-2012 12:48 PM
Carlton,
I may not be seeing it, but I only see one side on DLS1 where you posted the interface configs. Can you post the interface configs on DLS2? Also, you'll need to configure the switchports that are part of the trunk as L3 as well with "no switchport".
John
Please rate helpful posts...
03-26-2012 01:16 PM
03-26-2012 01:19 PM
Can you post "sh etherchannel detail" from both switches.
03-26-2012 01:24 PM
DLS1#show etherchan detail
Channel-group listing:
Group: 1
Group state = L3
Ports: 2 Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Et2/0
Port state = Down Not-in-Bndl
Channel group = 1 Mode = Active Gcchange = -
Port-channel = null GC = - Pseudo port-channel = Po1
Port index = 0 Load = 0x00 Protocol = LACP
Flags: S - Device is sending Slow LACPDUs F - Device is sending fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Local information:
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Et2/0 SA down 32768 0x1 0x0 0x201 0x45
Age of the port in the current state: 0d:00h:40m:17s
Port: Et2/1
Local information:
Et2/1 SA down 32768 0x1 0x0 0x202 0x45
Port-channels in the group:
Port-channel: Po1 (Primary Aggregator)
Age of the Port-channel = 0d:00h:19m:38s
Logical slot/port = 16/1 Number of ports = 0
HotStandBy port = null
Passive port list = Et2/0 Et2/1
Port state = Port-channel L3-Ag Ag-Not-Inuse
Protocol = LACP
Port security = Disabled
Fast-switchover = disabled
Load share deferral = disabled
DLS2#show etherchan detail
Group: 1
Group state = L3
Protocol: LACP
Minimum Links: 0
Ports in the group:
Port: Et2/0
Local information:
Age of the port in the current state: 0d:00h:39m:55s
Port: Et2/1
Local information:
Protocol = LACP
DLS2#
DLS2#
03-26-2012 01:41 PM
Did you create the port channel interface manually or was it created for you? I think things need to be recreated. Try deleting your PO interfaces and start from scratch. I don't see anything glaringly wrong in the config.
Can you post from DLS1:
sh int eth2/0 switchport
sh int eth2/1 switchport
and the same for the channel-group ports on DLS2?
03-26-2012 01:45 PM
HI Blakely,
It was created for me.
03-26-2012 01:48 PM
03-26-2012 01:52 PM
I believe you need to add the command "no switchport" to both of the Port-Channel interfaces (on both sides).
03-26-2012 02:03 PM
03-26-2012 02:10 PM
Errr ... I must be getting blind. In DLS2, I don't see what ports are members of your EtherChannel.
03-26-2012 02:12 PM
Carlton,
I'm confused. The first configs that you posted had the interface configurations listed in active mode, but these configurations don't show anything listed at all.
interface Port-channel1
ip address 172.16.1.1 255.255.255.252
interface Port-channel2
ip address 150.50.5.1 255.255.0.0
interface Ethernet0/0
no ip address
shutdown
duplex auto
interface Ethernet0/1
no ip address
shutdown
duplex auto
interface Ethernet0/2
no ip address
shutdown
duplex auto
interface Ethernet0/3
no ip address
shutdown
duplex auto
interface Ethernet1/0
switchport
switchport access vlan 100
duplex auto
interface Ethernet1/1
no ip address
shutdown
duplex auto
interface Ethernet1/2
no ip address
shutdown
duplex auto
interface Ethernet1/3
no ip address
shutdown
duplex auto
interface Ethernet2/0
no ip address
duplex auto
interface Ethernet2/1
no ip address
duplex auto
interface Ethernet2/2
no ip address
shutdown
duplex auto
interface Ethernet2/3
no ip address
shutdown
duplex auto
interface Ethernet3/0
no ip address
shutdown
duplex auto
interface Ethernet3/1
no ip address
shutdown
duplex auto
interface Ethernet3/2
no ip address
shutdown
duplex auto
interface Ethernet3/3
no ip address
shutdown
duplex auto
interface Vlan1
no ip address
shutdown
interface Vlan100
You don't have any ports configured on this switch according to this config.
03-26-2012 02:20 PM
What kind of switches are these where you only have 4 ports in a slot ?
03-26-2012 02:22 PM
Blakely
DLS2#show ver
Cisco IOS Software, Linux Software (LINUXL2-UPK9-M), Experimental Version 12.2(20100802:165548) [mtimm-mtrosel2iol 102]
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 02-Aug-10 10:05 by mtimm
ROM: Bootstrap program is Linux
DLS2 uptime is 15 minutes
System returned to ROM by reload at 0
System image file is "unix:/home/iou/herebedragons/ins1019/i86bi_linuxl2-upk9-ms"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Linux Unix (Intel-x86) processor with 138728K bytes of memory.
Processor board ID 2048196
16 Ethernet interfaces
128K bytes of NVRAM.
Configuration register is 0x0
DLS2#
03-26-2012 02:30 PM
Is this an emulator? I can't help you with this...I'm not even sure what it supports. This is IOU (IOS on Unix) and I've never played around with it. Glen made a good call by noticing the port count; something I didn't notice. The configuration itself is straightforward for L3 EC. Just make sure that the switchport is converted to a routed port.
