Please let me know if there is any site were i can get the EoL / EoS details for Cisco 9200 series switches.
The content you are looking for has been archived. View related content below.
Hi, I am working on a RFP where one of the specs says " the switch should support IEEE802.3ah ethernet link OAM and IEEE 802.1ag/ITU-T Y.1731" this is the only point which i am not able to find a reference in cisco documents, though we have a cisco 9...
Could you pls suggest cisco ethernet switch which should support 1G, 2.5G in RJ45 mode along with TSN, PTP protocol, IEEE 1588
Hi, I have a C2960L-SM and noticed that I can't connect over ssh anymore. I getssh_exchange_identification: Connection closed by remote host If I run show ip ssh it seems ssh is running:SSH Enabled - version 1.99 ... and so on What can I do? Especial...
Hi, if NIC are teamed on VMWARE and set to "route based on the orginating virtual id" do i need to port-channel on the cisco switch ?
There's two network monitoring accounts that constantly log in and out of my devices, and it's making it difficult to use logs to troubleshoot issues because the logs are totally clogged up with useless messages. I looked at the forums on how to drop...
Guys I am trying to determine what the difference between "full poe" and "poe"I am replacing a few WS-C3560G-48PS-S switches at my clients and need to make sure I am providing them with the same PoE functionality that they currently have with the WS-...
I think I already know the answer to this.Will an SFP-10G-SR work in the 4G model if the interface is set to 'speed 1000' ?It currently keeps err-disabling in the 9200, even with speed at 1000I have a 9200 connected to a CBS350 (which I am sure will ...
Hello,I have a question, so far I have only ever upgraded to the next or higher version. Now the planis to downgrade because there are connection interruptions. FYI, it is a stack of 2 3650-48PDswitches. Almost nothing is configured there except that...
Hi, I have two WS- c3750x-48T -L switches stacked - connected back to back with Stack cable. Now one of the switch failed and I have only WS- c3750X- 12 S stackable switch as SPARE with me. So can replace 48 Port with 12 Port ? Does it need an...
sw# show system resourcesLoad average: 1 minute: 0.33 5 minutes: 0.38 15 minutes: 0.31Processes : 576 total, 1 runningCPU states : 0.25% user, 1.00% kernel, 98.74% idle CPU0 states : 0.00% user, 0.00% kernel, 10...
Is there a better way to upgrade these yet?Obviously, I want to reboot after-hours. The install command still cannot be scheduled.install add file flash:cat9k_iosxe.17.09.05.SPA.bin activate commit prompt-level noneIf I do not do prompt-level none th...
Hi, can anyone please advise whether SFP+ cisco SFP-10G-T-X can be used on cisco 3850 network module? thanks in advance!
Greetings,On an international L2 VPN service, the customer is complaining about latency.Here are several ping tests on the 2 PE routers:RouterA#ping mpls pseudowire b.b.b.b vcid source a.a.a.a repeat nSuccess rate is 100 percent (100/100), round-trip...
1Gb catalyst switches has air intake from front and side and exhaust to the back. And no versions with reverse-airflow.I know many places where such switches installed port side to the hot corridor - so it intake hot air and blow to direction of col...
Subject | Author | Posted |
04-23-2024 08:31 AM | ||
04-23-2024 02:53 AM | ||
04-19-2024 05:58 AM | ||
04-17-2024 03:50 AM | ||
04-15-2024 06:06 PM |
User | Count |
11 | |
10 | |
8 | |
7 | |
6 |
