cisco sg 300 not powering cisco WAP
Jdilkantha
Hi Guys,
Does anyone know why a cisco sg 300 10pp would not power out a cisco WAP out of the box ?
I've consoled into the switch and made sure poe is administratively on etc but still wont power devices.
It sends data fine though.
Many thanks.
balaji.bandi
do you have enough power to power the WAP - check POE usage
Switch support only Limited power.
what WAP you trying to power using PoE.
BB
With regards to POE usage on the switch its only one cisco air 1142n being used on the whole switch. Nothing else is plugged in, yet it still wont power on.
The switch is working for data as a laptop plugged in will get connection.
But a cisco air 1142n which needs 13watts wont power on ?
