Cisco stackwise assistance
We currently have 3 switches in a stack.
switch 1 provision ws-c3750g-48ts
switch 2 provision ws-c3750g-24ts
switch 3 provision ws-c3750g-48ts
3750G1#show switch detail
Switch/Stack Mac Address : 0011.9270.xx
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
1       Member 001e.491e.xx     1      0       Ready
*2       Master 0011.9270.1xx     1      0       Ready
3       Member 0017.9470.xx     3      0       Ready
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  1        Ok         Ok                2        3
  2        Ok         Ok                3        1
  3        Ok         Ok                1        2
3750G#
Right now I have switch 4 configured as:
switch 4 provision ws-c3750g-24ts
Is that all that is needed and then just cable it in the same pattern?
Thank you.
2 Accepted Solutions
John
If you want to set the switches priority you can use the command: switch priority in global
While I've never done a hot swap of cables while the switches were live I believe you can do so. In the past I've always just powered them down to do so. I'm sure someone could provide better guidance on that than me.
From what I know, the cables can be swapped. If the whole stack isn't rebooted, then a reelection shouldn't occur as long as the master isn't rebooted. You can set your master by priority number like
switch 3 priority 15 (0 - 15 are valid)
1       Member 0024.50da.ff00     1      0       Ready
*2       Master 0012.d975.6100     15     0       Ready
3       Member 0013.1922.b000     14     0       Ready
4       Member 0013.1922.ea00     13     0       Ready
5       Member 0015.f937.6780     12     0       Ready
6       Member 001c.577a.a700     1      0       Ready
My switch master is 2. The priority is 15. If my stack reboots, my switch 2 will always come back up as master. On a side note, I've always shut my switch down that I was connecting the new cable to, to be on the safe side. =)
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
Should be. Make sure the switch that you're adding has the same IOS on it. I would set a window and downtime to add the switch to the stack. It may start negotiating for a stack master and bring the switch stack down until that happens.
HTH,
John
Hi John,
Are the cables hot swappable?
And how can I set the priorites of the switches so that there is no election and that the configuration won't change?
Thanks again,
    John
John
HTH,
John
