Cisco Switch high CPU - ARP Input
Hi all,
ich have two Access Switches - WS-C2960S-48TS-L 12.2(55)SE10, since some days i see high CPU.
These ar the Log entries:
.Oct 10 09:22:04.366: IP ARP: rcvd req src 172.18.12.214 9890.9699.5401, dst 172.18.1.50 Vlan1
.Oct 10 09:22:04.366: IP ARP: ignored gratuitous arp src 172.18.12.214 9890.9699.5401, dst 172.18.1.50 bcc4.9370.8840, interface Vlan1
there are src and dst from hundreds of ip addresses in the subnet 172.18.0.0/16
Any idea or recommendation for trobleshooting this?
Thank
Regards Marco
5 Replies 5
Leo Laohoo
Post the complete output to the command "sh proc cpu sort | ex 0.00".
Hi Leo,
SW-RZ1-2960S-018#sh proc cpu sort | ex 0.00
CPU utilization for five seconds: 99%/0%; one minute: 99%; five minutes: 99%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
10 1472311814 323935027 4545 87.79% 85.60% 85.52% 0 ARP Input
140 3611459203 376553553 9590 2.32% 2.95% 2.98% 0 Hulc LED Process
294 262 142 1845 0.68% 0.33% 0.07% 1 SSH Process
109 154717264 20013657 7730 0.68% 0.64% 0.64% 0 hpm counter proc
302 223693276 863296861 259 0.51% 0.57% 0.62% 0 IP SNMP
304 347388330 433361257 801 0.34% 1.02% 1.09% 0 SNMP ENGINE
180 73484467 551214419 133 0.25% 0.22% 0.23% 0 IP Input
149 43561877 4128806 10550 0.17% 0.18% 0.18% 0 HQM Stack Proces
71 9059944 92702930 97 0.08% 0.04% 0.03% 0 RedEarth Tx Mana
105 8621340 265917539 32 0.08% 0.06% 0.06% 0 hpm main process
195 7293948 21431300 340 0.08% 0.04% 0.05% 0 Spanning Tree
90 4312107 543604310 7 0.08% 0.04% 0.02% 0 HLFM address lea
33 5372538 3441204 1561 0.08% 0.04% 0.03% 0 Net Background
72 4002863 750997981 5 0.08% 0.05% 0.01% 0 RedEarth Rx Mana
SW-RZ1-2960S-018#
Wow.  That's high.
Post the config and the output to the command "sh version".
Hi, here the show run output
SW-RZ1-2960S-018#sh run
Building configuration...
Current configuration : 6572 bytes
! Last configuration change at 07:08:16 UTC Mon Oct 10 2016 by cisco
! NVRAM config last updated at 13:57:14 UTC Fri Oct 7 2016 by cisco
version 12.2
no service pad
service password-encryption
service unsupported-transceiver
hostname SW-RZ1-2960S-018
boot-start-marker
boot-end-marker
enable secret 5 xxxxx
enable password 7 xxxxx
username cisco password 7 xxxxx
aaa new-model
aaa session-id common
switch 1 provision ws-c2960s-48ts-l
ip domain-list marburg.lan
ip domain-name switch.xxxx.lan
ip name-server 172.18.1.x
crypto pki trustpoint TP-self-signed-2473625600
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2473625600
revocation-check none
rsakeypair TP-self-signed-2473625600
crypto pki certificate chain TP-self-signed-2473625600
certificate self-signed 01
30820249 308201B2 ........
quit
spanning-tree mode pvst
no errdisable detect cause gbic-invalid
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
spanning-tree portfast trunk
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
description LAGER-KG-2960G-116
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
description RZ1-2960G-017
interface Vlan1
ip address 172.18.2.xx 255.255.0.0
ip default-gateway 172.18.1.xxx
ip http server
ip http secure-server
snmp-server community public RO
snmp-server community macmon RW
snmp-server location RZ1
snmp-server contact INV32953
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps tty
snmp-server enable traps license
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps cluster
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps dot1x auth-fail-vlan guest-vlan no-auth-fail-vlan no-guest-vlan
snmp-server enable traps energywise
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps power-ethernet group 1-4
snmp-server enable traps power-ethernet police
snmp-server enable traps cpu threshold
snmp-server enable traps rep
snmp-server enable traps rtr
snmp-server enable traps vstack
snmp-server enable traps storm-control trap-rate 50
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps stackwise
snmp-server enable traps errdisable
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server host 172.18.1.xx public mac-notification snmp
line con 0
exec-timeout 0 0
password 7 xxxxx
line vty 0 4
password 7 xxxxx
transport input all
line vty 5 15
password 7 xxxxx
transport input all
ntp clock-period 22518261
end
And the Show Version Output
SW-RZ1-2960S-018#sh ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE10, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 11-Feb-15 11:59 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE1, RELEASE SOFTWARE (fc1)
SW-RZ1-2960S-018 uptime is 34 weeks, 2 days, 19 hours, 0 minutes
System restarted at 15:21:09 UTC Fri Feb 12 2016
System image file is "flash:/c2960s-universalk9-mz.122-55.SE10/c2960s-universalk9-mz.122-55.SE10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48TS-L (PowerPC) processor (revision Q0) with 131072K bytes of memory.
Processor board ID FOC1950W4XE
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : BC:C4:93:70:88:00
Motherboard assembly number : 73-11909-10
Power supply part number : 341-0327-06
Motherboard serial number : FOC19505CCL
Power supply serial number : LIT19151DXG
Model revision number : Q0
Motherboard revision number : A0
Model number : WS-C2960S-48TS-L
Daughterboard assembly number : 73-11933-04
Daughterboard serial number : FOC19503V0Y
System serial number : FOC1950W4XE
Top Assembly Part Number : 800-30950-07
Top Assembly Revision Number : C0
Version ID : V07
CLEI Code Number : CMML510ARA
Daughterboard revision number : A0
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960S-48TS-L 12.2(55)SE10 C2960S-UNIVERSALK9-M
Configuration register is 0xF
SW-RZ1-2960S-018#
Thanks to all, the Problem is solved. Somone activates "debug ip arp", since no deb all cpu is normal again.
Regards Marco
